DNS management for force9
- Everything else
- Re: DNS management for force9
02-10-2023 6:46 PM
I'm playing detective a little bit here, trying to migrate email for a friend to Google workspace. The friend is not tech savvy and has no contact with whoever set things up for them previously.
Whois tells me that the DNS servers are ns1.force9.net, and Google tells me that force9.net is part of plusnet.
Does anyone know the URL for the necessary DNS management portal? I can then try to reset the password or whatever is needed so I can make DNS changes.
Labels:
Message 1 of 3
(1,368 Views)
2 REPLIES 2
03-10-2023 8:24 AM
Just wanted to be clear, I'm not trying to change DNS for force9.net 😄
It is a domain that has the name servers set as ns1.force9.net etc. and I literally just need to know where to log in to make DNS changes.
Their email provider is shutting down service in the next couple of months so I need to help them sort this out.
Any help much appreciated.
Message 2 of 3
(1,329 Views)
03-10-2023 8:34 AM - edited 03-10-2023 8:34 AM
The domain control panel can be found at: https://www.plus.net/my.html?action=domainv2
It's limited on what you can do though.
Message 3 of 3
(1,319 Views)
- Everything else
