DNS Nameserver Change Request
aveley
Hello,
I need to request that the nameservers are changed on our domains hosted with PlusNet.
Domain Name management is very limited and the plan is to move the domain elsewhere. However we want to leave it registered with Plusnet until we have migrated our email and website services to another platform.
Please advise, thank you.
5 REPLIES 5
pjmarsh
Fixes: 24
Re: DNS Nameserver Change Request
Hi
Plusnet don't let you change the Nameservers whilst its hosted with them.
Fixes: 585
Changing the namservers of a PN hosted domain is not possible. However I dont think that's actually what you want to do!.
What you really want to do is move the registration first. This will leave the nameservers as they are and the domain remaining hosted by Plusnet. You then setup your new email and website hosting at your new provider and then when ready, you change the nameservers to the new hosting providers.
aveley
Thank you,
Will Plusnet Email and Web Hosting services continue unaffected if I transfer/register the domain on the new hosting provider?
(Noted your point about keeping nameservers pointing to Plusnet after)
Fixes: 585
It should do. However, if you purchase a hosting package from another supplier you should be able to configure everything before you even transfer the domain registration. So even if something goes awry after the domain transfer, then you can quickly change the namservers to the new hosting.
aveley
Thank you for your swift replies, much appreciated.
