Confused over whether I am Full Fibre or not.
flycatchers
According to Plusnet I can now upgrade from Part Fibre to Full Fibre. But according to the Openreach web site my address is “We have no plans to build Full Fibre to this property yet”. But do suggest copper broadband which I assume I am already on. I do know that the local exchange is Full Fibre priority. So if I choose one of the Plusnet options would that just use my existing cable and wiring? Or would the EE option be the way to go? Though as I have a legacy email and webspace and domain address with Plusnet would to keep that when it gets moved to Greenby.
7 REPLIES 7
Fixes: 105
Re: Confused over whether I am Full Fibre or not.
@flycatchers
Have a look at the following. If you can post a screen image (after hiding your details) of the results members of this forum can advise. Include any narrative below the results window.
RichardB
Seasoned Champion
Fixes: 39
The openreach FTTP  address checker appears to be broken.
All addresses I have checked,  even those with FTTP already available report "We have no plans to build Full Fibre to this property yet".
Fixes: 357
@RichardB It is, as you say 'broken' - even my address, which is FTTP enabled, says it isn't available.
Fixes: 558
It's working fine here
Fixes: 357
This is my result - and I've had FTTP since May 2024.Screenshot 2026-05-24 at 19-44-15 Fibre Checker Results.png
Fixes: 558
Ah! You're talking about the Openreach checker, yes that's wrong for me as well BUT  the BTwholesale checker is correct
Fixes: 1,491
Moderators Note
This topic has been moved from Broadband to Everything Else
