Change rDNS
Change rDNS
Hi all
Noticed the rDNS for my static reveals my username which isn't what i'd want.
Can this be changed to either adsb.2e0veb.com or something random?
6 REPLIES 6
Fixes: 577
Re: Change rDNS
@Anonymous  there are two possibilities for a change to the rDNS
1) it can be changed to <ip address>.plus.com
2) if you own a domain and can change DNS. Then provided you create a forward A record, then rDNS can be changed to that. So if you can create the A record for adsb.2e0veb.com pointing to your static IP then the rDNS can be changed to that.
I'm sure a staff member will be along shortly and then will either send a PM or raise a ticket for you to reply with details.
Re: Change rDNS
Thank you.
Already have the domain and sub pointing at this IP address. These are A+ Dynamic records due to the former ISP only allocating a dynamic ip address.
So the link is already there - and working! Mind you, if i do add an additional "A" record, i'll then have to suss out how to make that work with nginx. Am ok if it doesnt resolve to a host for now and can pick the rest us when time allows.
Alternatively, happy for it just to be the ip addy .plus.com - that said, i'd probably recommend that as the default to Plusnet as it is a little invasive for people to be sharing their username without being aware!
Fixes: 577
Re: Change rDNS
In that case you just need to wait for a staff member to pick this up. They'll confirm the details and then raise the request to NetOps to do the change.
adamwalker
Fixes: 223
Re: Change rDNS
Hi @Anonymous I've raised a task to Netops for you, that should get picked up within the next few days.
 Adam Walker
CameronRivera
Re: Change rDNS
I am facing a similar problem, should I ask it here?
SammyM
Fixes: 101
Re: Change rDNS
Hiya @CameronRivera
We can help with this, please can you send us a PM with your account username.
 Sammy M - Sheffield Team
