Change rDNS
robdmob
Change rDNS
Can I please have my rDNS changed to 4wc.kmr.uk.com? I currently have an A record on that domain pointing to my static IP so I hope that is sufficient to prove ownership.
6 REPLIES 6
adamwalker
Fixes: 223
Re: Change rDNS
Hi there robdmob, sure I've opened a ticket on your account, can you reply back to that please so we can get it authorised? https://www.plus.net/wizard/?p=view_question&id=223697882
Drop me a reply back on here when you have and I'll get it sent off to our net ops team, they should get it done within a day or two for us.
 Adam Walker
robdmob
Re: Change rDNS
Hi Adam, all done. Thank you for your help!
adamwalker
Fixes: 223
Re: Change rDNS
No worries! I've raised the necessarry task for you and I'll check back for updates when I'm back on shift on Wednesday. Give me a shout if there's anything I can help with in the meantime though, I'll be around until 6.30pm today.
 Adam Walker
adamwalker
Fixes: 223
Re: Change rDNS
Hi thre, just a quick update to let you know that the records have now been updated on our side so that should propagate fully within the next 24 hours from now.
 Adam Walker
robdmob
Re: Change rDNS
Perfect! Thanks again for your help.
adamwalker
Fixes: 223
Re: Change rDNS
No worries Rob! take care and do shout up if there's anything else I can help with.
 Adam Walker
