Change rDNS settings
jack_
I noticed my hostname includes my username and seems to be because I'm using a static IP. as I found the below info on the static IP page but the help assistant link doesn't go anywhere. How can I request my hostname is anonymised?
As standard, the rDNS for your IP address(es) is username.plus.com (where 'username' is your Account Username). If you need to change your rDNS settings, please request this through the Help Assistant.
2 REPLIES 2
Fixes: 585
Re: Change rDNS settings
@jack_  here!, and you've just done it. The help assistant link no longer works (as youve discovered) , a staff member will spot this post and arrange a request to NetOPS to change the rDNS.
MatthewWheeler
Fixes: 503
Hi @jack_
I've raised the request to have the rDNS updated for you.
All being well it should be done in the next 72 hours
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
