Can't reach NS&I login page
bobpullen
Fixes: 327
Re: Can't reach NS&I login page
@greygit1 wrote:
Hi Bob (and everyone)
Is that the traceroute that doesn't work, or the login to NS&I. Or both?
For me (on EE connection), login route works (as in I can get to the form), direct to https://secure.nsandi.com doesn't. The traceroute was just for info to show the AS assignments as per @Dan_the_Van's earlier post.
kehall
I'm seeing issues with other services (proshipping.royalmail.com) but same IP block , which started precisely 00:00 9th July.. I suspect there's a BGP update gone wrong with their upstream network provider to certain blocks of IPs that PlusNet (and possibly others) use.
Whois reports that IP range is allocated to Atos IT Services UK, and as it's only a small subset of the internet, I suspect they're none the wiser as to the issue until their customers (the service providers using their systems) raise a ticket with them, which may be the next hardest thing to do given the lack of access to the relevant technical people needed. I'm trying via my contacts at Royal Mail but unless you've had some experienced in the game of internet routing it's not easy to comprehend!
inetnum: 157.203.0.0 - 157.203.255.255
netname: UK-ATOSUK-20070407
country: GB
org: ORG-AISU1-RIPE
admin-c: ATOS5-RIPE
tech-c: ATOS5-RIPE
status: ALLOCATED PA
mnt-by: RIPE-NCC-HM-MNT
mnt-by: SEMA-UK-AS-MNT
mnt-lower: SEMA-UK-AS-MNT
mnt-routes: SEMA-UK-AS-MNT
created: 2015-06-19T12:07:34Z
last-modified: 2023-01-04T11:09:51Z
source: RIPE
organisation: ORG-AISU1-RIPE
org-name: Atos IT Services UK Ltd
country: GB
org-type: LIR
address: Second Floor, Mid City Place, 71 High Holborn,
address: WC1V 6EA
address: London
address: UNITED KINGDOM
phone: +448007833040
fax-no: +441616018842
admin-c: ATOS5-RIPE
tech-c: ATOS5-RIPE
abuse-c: AA30342-RIPE
mnt-ref: SEMA-UK-AS-MNT
mnt-ref: RIPE-NCC-HM-MNT
created: 2013-05-30T09:12:57Z
last-modified: 2022-12-16T16:54:22Z
source: RIPE # Filtered
role: ATOS Admin
address: 3300 Solihull Parkway
address: Birmingham Business Park
address: B37 7YQ
abuse-mailbox: UK.Abuse@atos.net
nic-hdl: ATOS5-RIPE
created: 2013-10-05T00:51:50Z
last-modified: 2013-10-05T03:40:17Z
% Information related to '157.203.60.0/24AS21369'
route: 157.203.60.0/24
descr: Atos UK
origin: AS21369
created: 2021-04-22T12:52:45Z
last-modified: 2021-04-22T12:52:45Z
source: RIPE
Fixes: 334
@Champnet Just checked, and no, it appears to be Zens' own servers, although I am going via the BT 'wires' - no CityFibre available here until mid-2025.
Champnet
Fixes: 18
So you are going through Openreach cabling ? Just trying to find a common feature among the blocked users.................
Fixes: 334
Yep - OR cabling.
Champnet
Fixes: 18
Seems to be Plusnet users connected on Openreach cabling - except @Mav 's other half...........
Fixes: 334
@Champnet  - see post #12. 😀
Champnet
Fixes: 18
@jab1 You can get to and see the login page ?
@Champnet
"Seems to be Plusnet users connected on Openreach cabling - except @Mav 's other half..........."
To repeat my question earlier in the thread, (possibly rhetorically):
Why are some PN users, eg the OP, @Clarissa, unable to access either the NS&I direct login page or the homepage, but others, including myself, although the direct link to the login page doesn't work, can still gain access to our NS&I accounts via their homepage and the link on there?
I'm on Plusnet FTTC.
Fixes: 334
Not via the link in the OP, no, @Champnet , but I can if I go via the 'homepage'.
Champnet
Fixes: 18
@jab1  @Anonymous    Illogical. From  the menu log in option callls https://www.nsandi.com/login which calls  https://secure.nsandi.com with additional qualifying text...............
Fixes: 334
I agree, @Champnet - but what is causing this illogical operation is way beyond my comprehension.
kehall
Is your IP address in the 84.92.192.0 range? Can check with whatismyip.com
inetnum: 84.92.192.0 - 84.92.255.255
netname: PLUSNET-DIAL-ADSL
descr: Dial-up and ADSL pool
descr: PlusNet Technologies Ltd
country: GB
admin-c: PLUS1-RIPE
tech-c: PNET2-RIPE
status: ASSIGNED PA
mnt-by: MAINT-AS6871
pvmb
Fixes: 6
@Anonymous wrote:
@Champnet
I'm on Plusnet FTTC..
So am I. But I too can get the NS&I homepage OK, but not the login page. Either directly or via the home page.
Champnet
Fixes: 18
I've enabled a VPN app on my iPad.
https://secure.nsandi.com returns a 'too many http requests' and https://secure2.nsandi.com hangs indefinately, but login through the menu does work - I didn't log in as I don't trust free VPN clients.
It does begin to look like an IP range block, some of us have an address begining with 2 and others 7, thats a big block.
@Mav could have the answer if he can work out the difference between his and his other half's connections..
