Can't reach NS&I login page
- Everything else
- Can't reach NS&I login page
Re: Can't reach NS&I login page
11-07-2024 5:05 PM
Do Zen have some sort of connection with the BT network?
Yes, they use BT Wholesale. At least for some of their connections , which includes our office FTTC.
11-07-2024 5:23 PM
If it seems so many are affected it would be nice for Plusnet to comment. I have a static IP address for what it's worth but this is required for work purposes.
The question is, is it an issue on the BT network or are NS & I blocking IP address ranges for some reason.
11-07-2024 6:38 PM
I've never had to log in to check for Premium Bond wins.
Have you tried https://www.nsandi.com/prize-checker ?
11-07-2024 6:57 PM
I check on the day using Google App (other apps are available), I also receive email notifications a few days later if I've won.
So no I haven't used that link, but I do see the login page for that now.
11-07-2024 7:40 PM
It works for me on Zen but my Zen fibre is provided via City Fibre thus it would appear to be an Openreach issue. Zen do use the Openreach network where City Fibre is not available.
11-07-2024 8:30 PM
Doesn't work for me on the EE Broadband line I'm currently connected to. Trace below: -
1. AS??? bob-surface-7.mshome.net 0.0% 40 4.5 2.4 0.3 8.1 1.8
2. AS??? home.gateway 0.0% 40 7.9 13.3 5.3 32.3 7.3
3. AS??? 172.16.17.177 0.0% 40 19.9 13.1 6.6 33.5 5.9
4. (waiting for reply)
5. AS2856 62.6.204.188 0.0% 40 13.1 23.8 12.7 67.8 9.9
6. AS2856 core2-pos14-1.birmingham.ukcore.bt.net 0.0% 40 15.6 19.3 12.9 40.0 6.7
7. AS2856 core2-hu0-15-0-4.colindale.ukcore.bt.n 0.0% 40 19.3 21.5 13.3 37.8 6.1
8. AS2856 acc3-hu0-9-1-0.colindale.ukcore.bt.net 0.0% 40 17.1 19.0 14.2 29.6 3.9
9. AS2856 217.38.123.105 0.0% 40 35.9 24.9 17.1 40.9 6.2
10. (waiting for reply)
11-07-2024 9:39 PM
This is rather strange but just tested again on my PN line with still no access but switching to SWMBO's connection (also PN, same bungalow) I do have access. Back to mine again and no access as before.
Not sure if it's important but the app works just fine from my connection.
Forum Moderator and Customer
11-07-2024 9:58 PM
Hi Bob (and everyone)
Is that the traceroute that doesn't work, or the login to NS&I. Or both?
Works for me (login-wise) on a Plusnet provided FTTP connection.
Minor obs. NS&I moved to 2-factor authentication a (little) while back. You require a mobile reception to obtain the second factor (as a very plain text message).
11-07-2024 10:00 PM
It seems those that are reporting the issue, myself included, aren't even able to access the login page to advance to 2-factor authentication.
11-07-2024 10:09 PM
Interesting. (That's currently the best reply I can think of).
I'm not on a fixed IP. Could that be a factor?
11-07-2024 10:12 PM
I don't have enough knowledge to answer that but can say that both SWMBO and myself have static IPs.
11-07-2024 10:44 PM
I have read upthread and think I see someone not on a Pnet connection has the same problem? So I've shot myself in the foot,
11-07-2024 11:27 PM
Similar problem here. Plusnet Fixed IP address.
I can connect via 4G and VPN. Can't get to login page otherwise - no error message or timeout, just does nothing.
12-07-2024 12:37 AM
https://secure.nsandi.com/ doesn't work for me.
Log in or register does work for me.
12-07-2024 6:29 AM
- Everything else
