Can't enable static IP
barlow1123
My new fibre went live recently. It has all been working well but I can't enable the static IP in the 'Add-ons' page, it constantly says "You are currently using a dynamic IP address"
Clicking the "Activate" button does nothing - just returns back to showing the same thing.
I paid the £5 before it all went live, so am presuming this has mucked things up.
Can you have a look into this please?
Thanks,
Craig
4 REPLIES 4
Fixes: 480
Re: Can't enable static IP
@barlow1123  Welcome to the Plusnet Community Fora.
It currently has to be activated manually. A Plusnet agent will pick this post up and activate it for you. After this is done you need to reboot the hub to pick up the new address.
MatthewWheeler
Fixes: 503
Hi @barlow1123
That's been sorted out for you now and if you reboot your router it should get picked up
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
barlow1123
Thank you! That has resolved the issue.
willcutforth
Fixes: 113
Awesome, glad to hear it! Do you need anything else at all?
 Will Cutforth
