Can't enable static IP
rpdm
My FTTP switch-over went live yesterday - all good except that I can't seem to enable static IP in the 'Add-ons' page.
Current Status :  You are currently using a dynamic IP address
Clicking Activate button does nothing - just returns back to showing the same thing.
I paid the £5 before it all went live, so am presuming this has mucked things up.
Any advice on fixing this?
Thanks,
Richard
22 REPLIES 22
Fixes: 585
Re: Can't enable static IP
The Add ons page for static IP hasnt worked for a while.
One of the Plusnet Help team will (hopefully) pick this thread up and enable your static IP manually
Fixes: 480
Moderators Note
This topic has been moved from Broadband to Everything Else
willcutforth
Fixes: 113
Hey there @rpdm I have enabled it now. Please can you turn the router off and back on and see if it has worked.
If not, let me know.
 Will Cutforth
rpdm
Thanks for your help on this.
A router reset appears to keep the IP address the same, although the plusnet page still says I’m using a dynamic address.
willcutforth
Fixes: 113
It seems to not have budged from our side so I will get my colleague to check it in the morning and if not we will need to raise a task to sort it. Sorry about this.
 Will Cutforth
rpdm
I've nudged Plus.net support as there's still no sign of action on this.
After a re-connection I've been given a different IP address, so definitely not static yet 😞
James30
Fixes: 32
@rpdm - That's done the trick. Just reboot your router to get it assigned.
James - Plusnet Sheffield
martynhsmith
Mines not working either
willcutforth
Fixes: 113
Hey there @martynhsmith I have done some adjustments to the static IP component on the account but I just need to give it 24 hours to see if it will work from there. If it doesn't then I will raise it to our network team.
 Will Cutforth
willcutforth
Fixes: 113
This should now be activated for you. Can you do a reboot please if not already?
 Will Cutforth
IanRLowe
Can I get a "me too"? please?
The form is also not working for me, and I need to enable the Static IP.
Cheers!
James30
Fixes: 32
@IanRLowe - Computer says no! Only because the username I have for you isn't right. Can you PM me your username Ian and I'll get it sorted. TA
IanRLowe
Cheers James, sent you a PM.
James30
Fixes: 32
@IanRLowe - I'm having issues replying to the DM but I got your message. I'm having issues sorting the static IP too, it's not going well. It's not clear if it's worked not but can you reboot the router and let me know when you have. Cheers.
