Battery Backup Unit
Fixes: 480
Re: Battery Backup Unit
@TR11Falmouth wrote:
Does the supplied cable / adaptors connect ok to the Plusnet SmartHub v2 and the Openreach ONT ?
Unfortunately not, you need adapters. 'Standard' 5.5mm outer diameter barrel connectors come with a dizzying number of pin sizes.
BT and Plusnet hubs use a non standard 5.5 x 3mm barrel connector. They are available see https://toothbrushbattery.com/buy/bt-smart-hub-home-hub-dc-power-plug-adaptor/. I have read of brave souls managing to jam a 5.5 x 2.5mm connector in, but would not recommend trying.
You will also need one for the ONT,  The ONT connector is 5.5 x 2.1mm.  These adapters are readily available
Fixes: 118
Although not directly related to this thread here's a guide on power backup.
https://www.thinkbroadband.com/guides/how-to-stay-online-if-uk-experiences-rolling-power-cuts
Fixes: 480
@bmc
An excellent article, It's a bit lengthy but includes all the salient facts relating to the best way to provide back up power tor a router and ONT during a power cut.
