BT Sport App help
Bamboozled
Fixes: 4
BT Sport App help
I pay Plusnet for BT Sport via App on PC but havent used it for "ages"
Fancied some footy last night but clicking App on Laptop it said [short story] that it was no longer available on App but was available via other Platforms - and listed maybe 20
I tried my Tablet and the App loaded fine but whatever prog I tried it would freeze after 5 seconds.
Realistically I would like to get to work on Laptop but can anyone tell me how to do this IF it is possible of course. Its a bog standard Acer Aspire ES 15
2 REPLIES 2
Fixes: 147
Re: BT Sport App help
It is still possible to use your laptop https://www.bt.com/sport  you'll need your BT ID and password.
With the mouse pointer over Sport drop down window appears, under 'Watch' select the stream you want
HTH
Bamboozled
Fixes: 4
Hi and thanks for the reply
I did find that method but only on my Tablet which kept freezing after seconds.
So I will try again via Laptop asap.Wont be as convenient as App but better than not having anything.
Many thanks again bamboozled
