Anyone else having Vodafone Sure Signal problems?
ITWorks
Fixes: 9
Re: Anyone else having Vodafone Sure Signal problems?
Mine has now gone back off again , wit the same problem as this morning
May i ask what services and hardware others have?  , i am on fibre 80/20 with the PN hub one
Andrue
's fine here. I was out playing golf earlier. Phone wasn't connected until I sent a text out but it all looks good still.
Hardware is a Billion 6300 and I'm on the 80/20 package with a static IP address.
danielmclean
i have been using plusnet Hub Zero for the past 2 weeks   without a problem with ss3  and was using  talktalk hg635   for 6 months   without fault
ITWorks
Fixes: 9
Anyone having problems with sure signal this morning , i get a solid red power light and constant white flashing globe .
Regards
Mike
danielmclean
mines is working     check the ip  and make sure its uk  and not a us one
ITWorks
Fixes: 9
IP fine , Mine has come back on ,, so obviously a Vodafone problem , i rang them back 9 spoke to them first thing)  , said they had been having issues for a week or so and been doing maintenance and pushing firmware updates out , and today is the last day for this work.
 Why the first person i spoke to this morning could not tell me this, instead of trying to blame  everything and anything apart from them  .
