ADSL offers
cbcadmin
Re: ADSL offers
I know ADSL is no longer available, but FTTP 40/10 should be, but I can’t find anyone able to supply this. Sad
I know 3Mbps is 3 x ADSL but it is only a third of what I should be getting on 40/10.
Keef- Sheerness Kent UK - Vodafone FTTP via THG3000 & Three via ZTE MF286D
Previously - NowTV, John Lewis, Shell Energy, Plusnet, Sky, EE, New Call Telecom/Fuelbroadband, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
Re: ADSL offers
Do you have any computer that is connected to your router with an ethernet cable ?
cbcadmin
Re: ADSL offers
No. Why does it refuse to post without five chars?
Re: ADSL offers
On your THG3000 router have you checked that the WiFi settings allow the widest bandwidth to give best throughput ?
Login to your router.
At the top right of the screen select "Expert Mode"
In the red bar, click on "Wi-Fi"
Then select the "Wi-Fi Settings" menu option
In the 2.4GHz section, ensure -
    "Wi-Fi Mode" is selected as "Mixed 802.11b/g/n"
    "Bandwidth" is set to "20/40MHz"
In the 5GHz section, ensure -
    "Wi-Fi Mode" is selected as "Mixed 802.11n/ac"
    "Bandwidth" is set to "20/40/80MHz"
cbcadmin
Re: ADSL offers
I haven’t but will do: thanks!
B/W was set to 20 not 20/40, so fingers crossed.
Although 5G was correct and that is what iPads use, but …..
cbcadmin
Re: ADSL offers
https://www.thinkbroadband.com/speedtest/1689885650200174655 after above adjustments.
Re: ADSL offers
1689885650200174655
Re: ADSL offers
What do your BTW IP profiles look like ?
If you first run the BT Wholesale Broadband Performance Test
then press the <Additional Diagnostic> button
then press <Telephone Number (DN) > button
enter your phone number in the "Telephone number of the broadband service" box below,
and then press <Run Diagnostic> button
Let the test run ... ... ...
and then post back here a screenshot of the results page
RealAleMadrid
Fixes: 68
Re: ADSL offers
@Anonymous  The Op is on FTTP there will be no telephone number associated with the Fibre line.
His speed problems are basically flawed testing using Ipads on Wi-FI.
Have a look at this BT Wholesale test result in my earlier post done with an Iphone with presumably better wi-fi speeds.
https://thumbsnap.com/fJMCNRSE
Looks about right for a 40/10 service.
cbcadmin
Re: ADSL offers
Where do I find my telephone number? I thought FTTP doesn't have a phone number any more?
cbcadmin
Re: ADSL offers
https://thumbsnap.com/sjQrWvXF
Re: ADSL offers
Screenshot 2023-07-21 at 08-43-11 ThumbSnap - Free Photo _ Video Sharing.png
Using the phone that did the above test, what results do you get with this speed test - https://www.waveform.com/tools/bufferbloat
cbcadmin
Re: ADSL offers
https://thumbsnap.com/K9MF99GM
cbcadmin
Re: ADSL offers
Reading the link below the results I see I need a router with SQM. Does my THG3000? And even less likely does the router supplied by TalkTalk have it? I know; I wouldn’t go for TalkTalk out of choice, but I can’t find anyone else to replace Vodafone. Sad
