ADDFREESTATS - server down? Or service folded?
forsterbalcke
The Addfreestats software on my web page no longer displays so I can't access my stats.
And I am unable to access their server!
Have they shut up shop and gone bust?
Bill
15 REPLIES 15
Oldjim
Resting Legend
Fixes: 63
Re: ADDFREESTATS - server down? Or service folded?
Interesting according to http://www.downforeveryoneorjustme.com/www.addfreestats.com/ it is up but I can't get there and a tracert gives up
Tracing route to www.addfreestats.com [66.118.182.112]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.0.1
  2    33 ms    33 ms    33 ms  lo0-central10.pcl-ag04.plus.net [195.166.128.185
  3    60 ms  217 ms    54 ms  link6-central10.pcl-gw02.plus.net [84.93.249.106
  4    32 ms    32 ms    75 ms  xe-1-2-0.pcl-cr02.plus.net [212.159.1.6]
  5    33 ms    33 ms    32 ms  ae1.ptw-cr02.plus.net [195.166.129.2]
  6    32 ms    32 ms    37 ms  lonap.he.net [193.203.5.128]
  7  107 ms  101 ms  101 ms  10gigabitethernet7-4.core1.nyc4.he.net [72.52.92.241]
  8  107 ms  115 ms  107 ms  10gigabitethernet2-3.core1.ash1.he.net [72.52.92.86]
  9  118 ms  119 ms  120 ms  10gigabitethernet1-2.core1.atl1.he.net [184.105.213.110]
10  120 ms  119 ms  118 ms  sago-networks.gigabitethernet2-13.core1.atl1.he.net [209.51.191.166]
11    *        *        *    Request timed out.
12    *        *        *    Request timed out.
13    *        *        *    Request timed out.
14    *        *
Fixes: 1,483
it's working here, using OpenDNS
Oldjim
Resting Legend
Fixes: 63
I am using the Google DNS servers
What is the IP address you get
Fixes: 1,483
traceroute to www.addfreestats.com (66.118.182.112), 64 hops max, 52 byte packets
1  192.168.0.1 (192.168.0.1)  2106.255 ms  1.231 ms  0.882 ms
2  cr0.mycsg.uk.easynet.net (195.189.159.117)  42.680 ms  140.842 ms  66.530 ms
3  80.238.54.33 (80.238.54.33)  39.659 ms  38.978 ms  38.328 ms
4  te0-1-0-5.er10.thlon.ov.easynet.net (89.200.134.127)  46.763 ms  51.305 ms *
5  ae3.lon10.ip4.tinet.net (77.67.74.93)  54.560 ms  45.907 ms  49.055 ms
6  141.136.109.133 (141.136.109.133)  167.054 ms
    141.136.109.129 (141.136.109.129)  147.401 ms
    141.136.109.121 (141.136.109.121)  159.198 ms
7  sago-gw.ip4.tinet.net (77.67.68.150)  159.303 ms  159.354 ms  157.467 ms
8  ve41.core01a.tpa.sagonet.net (63.246.159.45)  170.372 ms  167.445 ms  188.069 ms
9  65-110-32-17.static.sagonet.net (65.110.32.17)  170.385 ms  169.310 ms  166.415 ms
10  66-118-182-112.static.sagonet.net (66.118.182.112)  169.619 ms * *
Just a thought, I'm not on my PN connection at the moment.
Oldjim
Resting Legend
Fixes: 63
Looks like a routing problem
forsterbalcke
Would somebody translate this for me?
Server down? Or gone bust?
Bill
Oldjim
Resting Legend
Fixes: 63
Neither - it is routing problem from Plusnet - should be sorted out eventually
forsterbalcke
And a follow up question, please:-
I see lots of references on this Forum to WEBSTATS - apparently a service from Plusnet?
Is this something which is the same as ADFRESTATS? Counts page views and visitors?
And if so why use ADFREESTATS?
Have been using it for about two years since leaning about it on this Forum but find the figures given on my free version somewhat suspect.
But it does at least reveal trends. And areas of particular interest. And overseas visitors
Of course, if its gone bust, I shall need to find something to replace it.
Perhaps that something else already available on Plusnet?
Bill
Strat
Fixes: 565
It's not gone bust at the moment as I can browse it on my phone (T-Mobile).
I've attached a screen shot of the Plusnet webstats of my infrequently visited site.
Clicking on a month in the app gives much more detail for that month.
forsterbalcke
So, if its a "routing problem"  how do I get Plusnet to do something about it?
It's not that I only want to access the Adfreestats web site.
I also want to be able to check my access stats for my web site here: http://www.holywellhousepublishing.co.uk/
The Addfreestats software at the foot of each page is still there when I view source.
But it does not display on screen in normal view.
So I can't click on it to view my page access figures.
Is this what you mean by a "routing problem"?
And how do I get Plusnet to fix it?
Do I have to "raise a ticket"?
And where do I find one?
And what does it cost?
Sorry, kind of getting irritated - please excuse & advise me on what I ought to do.
And are other Adfreestats users having the same problem?
Or is it just me?
Bill
spraxyt
Resting Legend
Fixes: 75
You need to raise a ticket by logging into the Member Centre of your Plusnet account. Then click Help & Support on the top menu, then Help Assistant in the left hand menu.
Under Technical Support click More, then click Other at the bottom of the list. Type your message in the textbox.
Explain that there appears to be a routing problem from Plusnet to http://www.addfreestats.com (browsing to the site times out), refer to this topic and paste a tracert like those posted earlier in this thread into your ticket.
Finally submit it.
I've raised ticket #61583415 to provide a further report.
If you want to investigate using Plusnet webstats, while you are logged into the Member Centre click Website settings in the left hand menu. Then click Advanced Webstats and click the Activate button. You will have to wait until tomorrow for your initial stats to be generated.
Then visit the same location and click on one of your hosted domain names; enter your account username and password and you will be shown a monthly summary page. Scroll down, click a month name to see detailed stats for that month.
David
forsterbalcke
Thanks for the advice - quite complicated.
But have followed your advice to the letter.
And hope it leads to results.
Shall wait and see ...
At present would prefer to stick to what I know but would welcome comments from those who are familiar with both ADDFREESTATS and the PLUSNET WEB STATS.
How do they compare?
Which is best?
Bill
spraxyt
Resting Legend
Fixes: 75
My ticket has been passed to Networks for investigation after they confirmed several computers in Plusnet Towers were unable to reach the site. One can get to the site by using a proxy such as http://anonymouse.org but that won't help for feeding the stats from your pages.
With regard to using Plusnet webstats why not turn them on then form your own opinion from the results? You don't have to make any changes to your pages. If they don't meet your requirements you can always disable them again.
David
spraxyt
Resting Legend
Fixes: 75
A response has been added to my ticket to advise that Plusnet have contacted the technical contact of the network administrators where the routing problem occurs and are awaiting a response.
David
