123-Reg domain transfer to PlusNet
Clumpy
I have registered a domain with 123-reg and transferred it to Plus Net (see WHois below) but I can't see it on my Plus Net domain settings. What else do I need to do please?
    Domain name:
        darrylstrong.uk
    Data validation:
        Nominet was able to match the registrant's name and address against a 3rd party data source on 31-Jan-2023
    Registrar:
        Plusnet Plc [Tag = FORCE9]
        URL: https://www.plus.net
    Relevant dates:
        Registered on: 31-Jan-2023
        Expiry date:  31-Jan-2024
        Last updated:  31-Jan-2023
    Registration status:
        Registered until expiry date.
    Name servers:
        ns1.force9.net
        ns2.force9.net
    WHOIS lookup made at 12:16:28 31-Jan-2023
8 REPLIES 8
Fixes: 585
Re: 123-Reg domain transfer to PlusNet
AFAIK PlusNet no longer provide any domain hosting, so I am confused as to how you've managed to do that.
What have you done to attempt the transfer ?
Clumpy
I already have a domain hosted with them so I transferred the DNS and IPSTag over to them using the 123-reg website, basically followed the 123-reg instructions.
Fixes: 585
Ah! , that's not going to work!. Changing the IPSTAG does not in itself transfer the domain hosting, the receiving host needs to be expecting the transfer and have confirmed the hosting. I'm pretty sure that PlusNet will not accept new domains for hosting, even though you have an existing domain. Certainly without them confirming that they will host the domain beforehand, any transfer to them is not possible.
Clumpy
Ah, okay.. Dammit.
How to get it back then!?
Fixes: 585
Are you wanting to host the domain for email and/or website ?
I can suggest reasonable cost alternatives if you would like.
Clumpy
Yes, domain and emails. Any pointers would be great!
Fixes: 585
No problem.
I use both Ecohosting and Mythic Beasts for my domains but for email only. Both are UK based and pretty responsive to support requests.
Ecohosting is more cost effective if you just need email. Mythic is better for combined web hosting and email. Ecohosting uses the standard CPanel for configuration whereas Mythic uses their own tools.  Mythic will support multiple domains on all account levels whereas you need higher tier (expensive) accounts with Ecohosting.
Some links
https://www.ecohosting.co.uk/hosting.html
https://www.ecohosting.co.uk/email.html
https://www.mythic-beasts.com/hosting ( if you pay quarterly or annually its slightly cheaper )
Hope that's useful. Shout up if youve got any questions
Clumpy
Very useful, thank you Smiley
