webmail problem
Fixes: 1,664
Re: webmail problem
Thanks for getting back to me @leo44
Could you private message me a screenshot showing what you're seeing so I can take a closer look?
leo44
Re: webmail problem
Hi I'm not quite sure how to do that, I cant see anywhere here is it though facebook?
Fixes: 1,664
Re: webmail problem
You can private message us on Facebook Messenger and we'll pick it up though it's probably easier to private message me via our Community Forums here to keep things in one place. To do that you'll just need to click on my forum username "Gandalf" then you'll see a button that says "Send Private Message"
bainhouse
Re: webmail problem
Apologies if am in the wrong forum page but cannot seem to start a new topic anywhere with my current problem.
Could someone please help me and let me know how I can delete old folders from my online plusnet webmail?  I have tried clicking on the small cog wheel at the bottom of each folder I want to remove but nothing seems to happen.
Also, if I close my online plusnet webmail will I still be able to use my plusnet email account in Outlook?
Many thanks again and sorry if I am in the wrong forum place
Margot
Fixes: 388
Re: webmail problem
@bainhouse To start a new topic - click the big pink 'New Topic' button at the top of each forum.
If you do not wish to use webmail, you don't really need to delete old folders from it - just make sure they are empty.
You cannot 'close' webmail, that is the bedrock of the mail system, and the place Outlook 'finds' the mail.
How is your Outlook client set up - as IMAP or POP3?
bainhouse
Re: webmail problem
Hi John
thank you for getting back to me so quickly.  There is no a "New Topic" button even when logged in to any of  the Community Forums when I want to post something.  Hence my going to the "reply" button for help!
I am trying to delete the massive amount of old folders from plusnet webmail to tidy things up.
At the moment my Outlook is set up as IMAP  as follows:  OUT:  imap.plus.net with port 993   and IN: relay.plus.net Port 465.
My outlook box keeps loading my old webmail folders and also the same applies to my iphone. I want to get rid of these old folders.    Could it be a synchronization problem?      Any help would be gratefully received as have been trying to sort this out for 2 days now!
Cheers Margot
Fixes: 388
Re: webmail problem
Hiya Margot. Sorry, still don't get why you don't see what I do at the top of each board:-
Im afraid someone else ( @Townman  ?) is probably the people to help you on your clean-up task, as I have always used a client for my mail, so don't know the finer points of webmail - sorry.
I have a feeling you have got your IMAP settings the wrong way round (in your post) as it would never work if really sey up that way. I understand now why you want rid of those extra folders, but  as above, it is not something I feel competent to help with. It is not a synchronisation problem - a client set up under IMAP is designed to fetch all the folders available, whether they have content or not.
bainhouse
Re: webmail problem
Many many thanks again John.   Will check out my mail settings again and see if I have this wrong.
Great advice!
Fixes: 251
Re: webmail problem
Glad to learn that you fixed your Outlook server settings.
leo44
Re: webmail problem
That's odd Townman, I don't recall having a problem with my Outlook server settings, when was this?
Fixes: 251
Re: webmail problem
Reply was to the previous poster..,
leo44
Re: webmail problem
Ah. nothing to do with me??? I cannot unerstander why I should get my email box littered up with junk that is not in the slightist bit relevent.
Anoush
Aspiring Hero
Fixes: 139
Re: webmail problem
You can unsubscribe to stop e-mail notifications to you from replies on this topic by clicking on Thread Options at the top or bottom of the page and then ‘Unsubscribe’
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Fixes: 251
Re: webmail problem
@leo44
Depending on your forum user settings you might see emails on topics you created and those you’ve commented on. You can turn off email notifications if they irritate you (see user settings) as well as unsubscribing from individual topics as advised above.
jadavis
Re: webmail problem
hello. I have lost all of my emails apart from the last few, plus the folders I had created to save emails to. Could someone help me get them restored? Apologies if I have posted in the wrong place.
thank you.
Jenny
