webmail inbox
gilbro
webmail inbox
Hi can someone help please. My plusnet webmail (totalise account) has not downloaded inbox for the last 3 days and I have important medical emails missing. I have reduced the inbox size by 20% but still no movement. Thank you in advance.
Tags (1)
7 REPLIES 7
Gel
Champion
Fixes: 29
Re: webmail inbox
Have you not got an e mail client you can use? [Thunderbird/ M/Soft Outlook etc] Never understood people who are totally reliant on an ISP's webmail. [PN of course are withdrawing their e mail service in the near future].
Tags (1)
Fixes: 392
Re: webmail inbox
Who says?
Tags (1)
gilbro
Re: webmail inbox
Hi I have a gmail email but sorry, don't see how this helps to retrieve PlusNet missing inbox mails.
Tags (1)
Fixes: 392
Re: webmail inbox
Your Gmail account won't help you.
After you 'reduced your inbox by 20%', did you also clear the 'deleted' folder and compact your inbox?
Tags (1)
gilbro
Re: webmail inbox
thanks for the reply. yes did both of those.
Tags (1)
Fixes: 392
Re: webmail inbox
I'm out of ideas then - I don't use webmail, so don't have the issue, and to be honest don't know what to suggest next.
@MisterW - any thoughts?
Tags (1)
gilbro
Re: webmail inbox
thanks jab1 very grateful for your replies. just compacted in box again and random mails during the missing period have started to slowly appear. very very grateful thanks.
Tags (1)
