reduce mail box size
Fixes: 387
Re: reduce mail box size
Because @Townman is not Plusnet staff.
stathe
Maybe you can ?? Thank you Seems I may be with you forsome time as our broadfband people have gone back to???
Fixes: 387
I doubt it - I am just another forum member like you - and not even a PN customer any more.
@stathe
reading some of your previous posts you appear to have a slow connection which will not help with your issue.
Do you have a relative or friend who has a faster connection speed and who might be able to help you?
Webmail can be used any any network not just plusnets.
Tina11192
Fixes: 18
Hi @stathe thank you for your time on call this afternoon.
I look forward to speaking to you again when I follow up next week.
Cri Ignatti
stathe
This charming lady is helping me Really appreciated
stathe
Unable to get webmail   now
lahbrannan1
Fixes: 4
Hi @stathe
I am sorry to learn of the issues you are issues you are facing with webmail.
Please could you elaborate on exactly what you mean by 'unable to get webmail now'? Presumably, you are unable to login?
Lee Brannan
stathe
Slow.and.wont log.in
Fixes: 251
@stathe wrote:
I seem unable to do any of this on webmail as the responses are not there and it just disconnects and I have to wait ages to get there again
@Tina11192 / @lahbrannan1
I wonder if we are looking in the wrong direction here - is it possible that the user has a line fault and their broadband is disconnecting frequently / performing slowly?  There is not much precision in the information being provided about using webmail, if indeed they are using the webmail interface ... rather than an email application / client.
Webmail can be slow, but not this bad unless the mailbox is massive due to never undertaking housekeeping coupled with there being a non-standard sort sequence within webmail as documented elsewhere on this board.
Tina11192
Fixes: 18
Thank you for flagging this @Townman I will pick this up shortly.
Cri Ignatti
stathe
I find it imposible to reduce mailbox size as it is all so slow You must do n=it forme
Marsh
Fixes: 41
Hey @stathe,
Navigating the website can be slow if you have a large number of emails in your mailbox. However, as you delete some emails, the speed will gradually improve
Josh
stathe
Unfortunatel;y I find this beyond myn comprehension
Fixes: 480
@stathe
If I remember correctly, you have previously reported that you have a very slow ADSL connection at your property. Is this still the case?
