outgoing emails to gmail
GlassySue
I have a legacy Madasafish email address ending with icscotland.net Over the last week I have noticed issues with receiving and sending emails.  I am not abe to send and receive emails but cannot sent to gmail accounts.  My account is a standalone so no plus net domain, or ano other for that matter.  I have adjusted varous server settings as suggested but this is still not working.  Any help would be appreciated
12 REPLIES 12
Fixes: 388
Re: outgoing emails to gmail
@GlassySue Are you still with Plusnet?
Fixes: 585
@GlassySue this thread https://community.plus.net/t5/Email/Cannot-send-to-gmail-addresses/td-p/1934005 probably explains why you have a problem sending to Gmail. I suspect the icscotland.net visp domain doesn't have SPF or DKIM . If that's the case then I'm afraid you probably need to consider an alternative email provider.
One thing that MIGHT just work is to replace the gmail.com with Google mail.com in the. destination address. They reference the same mailbox but the checks on Google mail addresses can be less stringent
Fixes: 388
Should that be 'googlemail.com', @MisterW ?
GlassySue
I was never officially with Plusnet, I can;t remember the original email provider but it was taken over by someone then by Madasafish and then Plusnet so a real legacy email.
GlassySue
not really tech savvy as far as this is concerned, do you mean change the persons email address that I am trying to send to or something to do with my own email?
Fixes: 388
OK, so I gather from that your ISP (now) is someone else? No matter, as @MisterW says, try putting 'googlemail.com' , rather than 'gmail.com'.
GlassySue
would also be interested in trying to understand why this has only happened in the last week.
Fixes: 388
Yep - change their address to '[email protected]'
Fixes: 388
The wonders of gmail, I'm afraid.
Fixes: 585
@jab1 thanks , yes it should be, ( I blame the spool chucker )
@GlassySue to explain, SPF & DKIM are advisory standards that have been introduced over the last few years in an attempt to reduce the volume of spam email. The problem is that google ( and microsoft hotmail to some extent ) have unlilaterally decided that these standards will be mandatory for email sent to their mail systems. They've been gradually introducing the requirement accross their systems over many months. So I suspect the requiremnt has recently been applied to the gmail address to which you are sending.
GlassySue
There was a fix on one of the forums that send that SPF had been added to icscottland servers which was accepted as a fix but I still can't send to gmail.com addresses  i thhink that he wrote about it in 2023.  the fix was added by a useer called Townsend.
Fixes: 585
@GlassySue  I did check earlier on, and icscotland.net does not have an SPF record
