ic24.net webmail
mombic
ic24.net webmail
I'm unable to login to my main ic24.net account although a 2nd account is fine. I've checked all the setting with the working Ac and there's no issue there and password is correct. This is the first problem with it in 20 years and I thought it bomb proof.
All help most welcome.
20 REPLIES 20
mombic
Re: ic24.net webmail
Update.
It seems my ic24.net Ac went down at about 23:00 on Monday 11 November and coincided with 3 e-mails being sent from a Gmail Ac. 2 mails arrived the 3rd didn’t, making me think the Plusnet mail server found something bad in that mail and de activated my Ac.
I have also found I’m not able to up date my website also linked to my main ic24 Ac. Clearly that a major problem as I run a help group for pensioners from it.
Is there anyway I can re activate my account or do you know anyone who can – this is now mega urgent please help.
mombic
Update 20-11-2024.
There’s been a suggestion that my password on webmail is corrupted. So how do I change it when I can’t login to webmail to change it?
Fixes: 251
You can change through the user portal. Passwords are not changed via webmail.
If you cannot log into the user portal then you will need to call support.
mombic
Many thanks Townman. Do you mean by Portal the main Plusnet home page I first login too. If so I can’t anything that mentions how to change my webmail password on that page.
Please could you write down the path to it?
Fixes: 388
@mombic To manage/edit your mailboxes, log into your account, and then, if your homepage is the same as mine, click the 'Manage account (top right), and scroll to the bottom of the resulting page, where you should see 'Manage Your Plusnet mailboxes'.
Fixes: 251
Now I am back at my desk, I can access my standard responses...
Reset email password
If you are not able to login to the email address using webmail, then it is likely that your email address has been identified as being compromised and has had its password changed. Where email address passwords have been changed to protect the integrity of the service, the Plusnet account password is left unchanged.
Which ISP are you with, Plusnet or one of the other / legacy vISPs?
Plusnet / Force9 / FreeOnline users can only change the password on the DEFAULT email address by changing the password on the user ACCOUNT through the user portal. You can change the password on a secondary mailbox using the Manage My Mail options in the user portal.
Brightview users (Madasafish / FreeNetName / GlobalNet / IC24 / ICScotland / Dialstart / Totalise) logging into webmail should use their full email address. Use the MAAF user portal to update the password on the default email address (change the account password) and use this MAAF guide to change the password on a secondary mailbox address. If you cannot recall the account password, you will need to contact support ... because the account password change process sends an email to the mailbox you cannot now access.
DO NOT USE THE SAME PASSWORD AGAIN for that would allow the continued exploitation of the account. The new password should be cryptic and not one used before.
Note that changing the account password will change the password used for logging on to the relevant user portal. If your email service is NOT a retained legacy service (one associated with a retired internet service account), then the password required by the router to connect to the internet will be changed too. If the router is a Hub Zero, Hub One or Hub Two supplied by Plusnet it should update automatically. If not, you will need to log into the router, drop the connection, change the password yourself and reconnect.
On the assumption that the email address password has been compromised, I strongly recommend that wherever you have used that email address / password combination as access credentials to services such as Amazon, Netflix, eBay etc., that you also change the passwords on those service as well.
mombic
Thanks Jab1. My account details have no mention of Webmail Ac’s and the only change p/w is for my main login.
Have to take you know how to do the shopping so back later.
Fixes: 388
@mombic See @Townman 's response above - he is more knowledgable on this subject.
mombic
Many thanks Towman,
From memory my journey to Plusnet started at Freeserve in the late 80’s. though Talk Talk. PO. SSE. Madasafish and then becoming a Plusnet member 2004ish following the buyout?
In order to keep the password issue simple to Webmail I didn’t mention that the login issue also affects normal email through Outlook for Windows as well as my website hosted by Plusnet.
I have followed and tried all the suggestions on this thread, as well as others on the general email forum, Alas I have been unable to find anyway of separately /only changing my email password.
The route via my Portal/Member-Centre, -  Account – change password, only changes the password needed to enter the ‘Portal’.
I have now spent countless hours trawling Plusnet’s help articles since Monday 11th on this – that should have been a simple operation to reactivate my email account/settings.
So as a last resort. If there’s anyone reading this that has contact with an engineer who has an in depth knowledge of Plusnet’s email server/equipment I will be most grateful if they could bring my case to their attention.
PS. The only way to contact me is via this Forum or phone No in my Ac as I have NO email.
mombic
Update 22-11-24.
Morning all,
Am I correct in understanding that either my user name or email address can be used to login to the member centre?
If I am correct and now that email address doesn’t log me in to the member centre, will that also cause a ‘Login Failure’ on email?
All replies most urgently welcome.
Fixes: 251
You can login to the member centre only with your account name.
You can authenticate with the email servers using the account name or the email address.
mombic
What I find Townman is when you log into the Member Centre/Portal at the Broadband login page there’s 2 boxes to enter details.
Top one is called ‘Username or email address’ so I entered the username I’ve used for the pass 20+years.
Bottom is called Password. So entered my normal one. Hit enter and I’m logged in with no problem.
So in the knowledge that Username and Password is ok I repeated the above except using the email address ******@ic24.net I’ve used again for over 20years as Username, hit enter and the message was: “oop’s your address or p/w is incorrect”.
So for completeness I logged into Webmail for Plusnet and 2 boxes appeared.
Username was asked for and used the same as above I know works.
Password used was the normal one I know works. So hit enter and “Login Failed” appeared.
Finally. Used the above but with the ******@ic24.net I’ve used, again for over 20years.
For the Username. Hit enter and the message was: “Login Failed”.
So ******@ic24.net fails on both Member Centre and Webmail, so where is the problem remembering at the start it says ‘Username or email address’? Surely not the Plusnet email server/software or their configuration?
Fixes: 251
AFAIK regardless of what the member centre states it is not possible to log into there using an email address.
It is possible to log into webmail using an email address but it appears to be treated as a separate identity to that when logging into the same mailbox using the account name. I have always used accountname or accountname+Mailboxname - I just logged into one such mailbox using its email address and was prompted to enter an identity.
Where is this leading to? The query is about logging into Mail. Both webmail or another client can use accountname or email address. Email passwords are managed via the user portal which CAN be accessed via the accountname.
I will flag up the matter of it suggesting that access using an email address does not seem to work.
Fixes: 251
UPDATE: You can log into the user portal using AN email address - it seems to need to be** the CONTACT email address as specified here - Manage Account | Member Centre | Plusnet
That email address might not be the same as the default or main email address defined within the email service.  For example my default** email address is [email protected] (aka [email protected]) where as the contact address is postmaster@
Hope that clarifies ... old dog learnt a new trick today.
** I have raised an enquiry to clarify / confirm this - I am aware that many years ago I renamed the default email address ... which might have been called postmaster@
