email problems
billswan
email problems
Is it just me, or is the mail service down?  My email address is, for historical reasons, a globalnet one but it's delivered (or not, currently) by Plusnet (following their swallowing-up of first globalnet, then madasafish).
4 REPLIES 4
Fixes: 388
Re: email problems
@billswan It is still working - for Plusnet addresses, anyway. What's your problem?
Fixes: 251
Re: email problems
Probably a full mailbox. The legacy brands only have 250MB of storage.
billswan
Re: email problems
I rebooted everything - router factory re-set, power off, on, PC shutdown, full power off then full start-up.  And it's now working fine.
I'm sorry to have troubled you - I have no idea what the problem was.  I use MS:Outlook client for my email (not webmail) so all messages are downloaded, and not stored on and clogging up a Plusnet server.
Thank you.
Fixes: 251
Re: email problems
Is the outlook client configured as POP3?
If you access the mailbox using webmail, what does it find in the mailbox?
