Webmail problems
stathe
Webmail problems
Seem unable to sign into Webmail what is the secret to this
7 REPLIES 7
Fixes: 241
Re: Webmail problems
Unable in what way?
Have you already got email on your Plusnet account?
If yes, then you access the DEFAULT mailbox using your ACCOUNT_NAME and the account password.
Secondary mailboxes are accessed using ACCOUNT_NAME+MAILBOX_NAME and the password for the mailbox.
stathe
I have had a plusnet account for years so presumed it was there, and it has been. I have my name and password in the box and it says login failed every time It has always taken a long time
stathe
unfortunately I have no idea what you mean me to do
stathe
Sorry    I think I may have a different password now so will try when I find it  IF
LaurenB
Fixes: 131
Hiya @stathe, thanks for getting in touch!
I'm sorry to hear you're experiencing some issues trying to access your mail and would like to help with this for you:
As @Townman mentioned, if accessing the default mailbox you just need to use your account username to log in and the password would be the same as your account password you use to log in to the member centre.
If accessing an additional mailbox you set up, the username would need to be entered in the format 'username+mailbox' and the password for this would be different to the account password. If you need to reset it, you can do so by logging in to your member centre, going to the manage mail section and under the mailboxes option, there should be an option to amend next to the required mailbox and you can change the password for it.
Let us know how you get on.
 Lauren Barry
stathe
At some stage I changed my plusnet password and not here (saves password ) I started again with the changed Password and its O K
LaurenB
Fixes: 131
OK, thanks for the update, I'm pleased it's now OK Smiley Should you need any further support at all please do just let me know.
 Lauren Barry
