WEBMAIL distortion using I Explorer 10
Gel
Aspiring Champion
Fixes: 29
4 REPLIES 4
Oldjim
Resting Legend
Fixes: 63
Re: WEBMAIL distortion using I Explorer 10
An aside - works fine in IE11
Gel
Aspiring Champion
Fixes: 29
Thanks OldJim.
I know a lot of sites don't run well on IE10; I also have Avant installed, and is OK there, but have to use IE10 on work laptop.
It also seems to have issues, as does Avant , with some websites such as Energy Coy/Bank where you need to d/load a pdf;
you just seem to end up with blank page.
Sometimes right clicking & "Save Target As" works; not always.
Lots of people seem to have issue, but none of suggested work rounds finally fix.
I'm thinking it's an Adobe issue as also experience with Avant on some www's.
drj
Quote from: Gel
There seems to be an issue with Webmail in IE10; as you can see from screenshot the cc & bcc boxes are all squashed up!
Just tried on my office machine - where I usually access webmail using Chrome since that separates it from work using IE10. Almost exactly the same problem as you pictured - and it's the same for the "Reply-To" and "Follow-Up" boxes too. Unusual to see a website not being formatted correctly in IE.
Gel
Aspiring Champion
Fixes: 29
Believe a lot of sites have IE10 rendering issues, even PlusNet!!
I've noticed on one e commerce site that some of links will not work, unless favourites bar shut first;
others will however. (ie arrow doesn't change to a hand when hovered over).
I've reported the behaviour to them that they were unaware of, having only checked
compatibility with other browsers.
