Unable to send email using Three MiFi dongle
- Re: Unable to send email using Three MiFi dongle
12-03-2012 5:07 PM
I've done some checking and it looks like this has been enabled on relay.force9.co.uk and relay.free-online.co.uk but there's something that needs changing before it'll work on plusnet (I think it's a firewall config). We'll chase our networks team about that one, but in the mean time anyone on plusnet can use either of the above two servers on port 587 and it'll work fine.
13-03-2012 1:01 AM
31-03-2012 3:25 PM
I would appreciate help from anyone who has succesfully managed to set up to send email from outlook via Three.
Problem sending email from laptop while tethering to an iPhone on Three
31-03-2012 3:30 PM
PN customer support sends me back to Three saying it must be a problem at their end. Three are clear that as long as PN allows the use of port 25 it will work, so it must be a PN problem.
Any help from anyone who has managed to send email via outlook while connected to Three will be much appreciated; or indeed help from anyone who can offer any other advice or suggestions.
And yes, I'm aware I could use webmail, Gmail, etc but for number of reasons prefer and need to be able to use Outlook.
31-03-2012 4:42 PM
Question for Spark - do you mean you can't send email as you say you can't receive them
31-03-2012 5:09 PM
31-03-2012 5:42 PM
Authentication is used when you are using a non-Plusnet connection to send via relay.plus.net. You can't do this over a three connection - three block port 25 to anything other than their own server.
Three will allow you to send over a different port, but there is no point, because Plusnet will only accept mail via port 25.
I use Thunderbird rather than Outlook, but the principle is the same. The only difference is that Outlook's setup screens are fairly impenetrable at first sight, while Thunderbird's are simplicity itself. The beauty of Thunderbird is that it has one small window that deals with the outgoing server for all accounts, so swapping server as you move from home/office to mobile is about three mouse clicks. No - 6. I just counted them. And nothing to type; just switch server.
31-03-2012 5:51 PM
The point of using smtp-mbb.three.co.uk is that it allows you to set your Plusnet email address as the senders address (the normal three server doesn't allow that). You have to use the three login and password - not your Plusnet ones.
31-03-2012 6:29 PM
I can't easily check for certain, because Thunderbird never shows even if a password is stored, much less what it is. I can see that the three server settings box has the username as 'unspecified' & I know it doesn't ask for it as it sends mail.
You are correct about the importance of specifying three's mobile smtp server rather than their standard one. It's confusing, because most of their help documentation refers to the standard server (or it did when I last looked, which must be a couple of years ago now) & I remember it was a real detective game to get the name of the correct server. The '-mbb' (mobile broadband?) is the vital distinction to be able to use your own email address - not necessarily your Plusnet one. Just as well, because I don't have a three email address - I don't think it's a service they provide to their mobile broadband customers.
I think there must be more help on this topic scattered about this forum now than there is on three's own help pages. If anyone with technical writing skills wanted to collate it all into a Library article, I'm sure it would be welcomed. Might even be able to flog the result to three as well!
03-04-2012 5:45 PM
Quote from: Oldjim Topics merged to keep the problem in one place and hopefully find a solution
Thanks Oldjim. Yes, sorry, I mean I can't send.
Quote from: jelv Could you confirm which version of Outlook you are using please.
I am using Outlook 2007.
Simon M has solved the problem for me. You are right, I still had authentication switched on, doh!
To recap for anyone else with this problem:
To use three mobile for tethering, you have to change the outgoing server to smtp-mbb.three.co.uk, and make sure you have outgoing server authentication turned off.
04-04-2012 5:44 PM
Quote from: Matt Hi all,
Not in my case it won't.
Tried everything here and on other forums, nada.
This is very frustrating. I even installed Thunderbird and created a fresh account in that and nothing works.
I even had a friend help me and he couldn't sort it either.
04-04-2012 9:04 PM
I think that should be relay.force9.net.
That does get me a connection which works. However, when I turned authentication on (which would be needed from a non-Plusnet connection), it didn't seem to like my password. There are two possible explanations for this. Either Force9 doesn't recognise a Plusnet username/password combination, or I put the wrong password in. Remind me - this is the main account username/password combination that it required, isn't it?
05-04-2012 12:58 AM
However as I speculated in Reply #16 only Force9 customers can use that for authenticated connections because only Force9 usernames and passwords are recognised by that server. It has to be like that because the same username can occur on Force9, Plusnet and Free online,
10-04-2012 6:34 PM
We set our macbookpro's side by side with our own Three MiFi dongles hooked up to the internet then we both logged into each others MiFi dongles (it's okay we're consenting adults) What was the difference?
He could send and receive email using mac mail on both three dongles. I on the other hand can only receive.
Conclusion: Plusnet is the problem not Three dongle.
Can someone make a concerted effort at plusnet to get this resolved. We spent two hours last week trying to sort this using all possible combinations of previous solutions on the plusnet forum (and elsewhere) but I still can't reply to emails unless I go into webmail which is not convenient.
Regards
10-04-2012 8:33 PM
Either that or he is using three's smtp server.
I take it that you haven't managed to persuade your email client to use smtp-mbb.three.co.uk?
