Strange URL
Silverwhistle
Fixes: 4
Strange URL
I clicked on my webmail bookmark earlier and it appeared as: https://webmail.plus.net/squirrelmail/src/login.php
What is this, please?
10 REPLIES 10
Fixes: 251
Re: Strange URL
The web address of Plusnet's Squirrel Mail web service.
Silverwhistle
Fixes: 4
Re: Strange URL
Not sure why it appeared: I've never used Squirrel!
Fixes: 480
Re: Strange URL
@Silverwhistle
You may not have realised it but if you've used Plusnet webmail then you've used squirrel mail.
Fixes: 251
Re: Strange URL
Squirrel is the BASIC webmail. The normal webmail client is roundcube.
Fixes: 480
Re: Strange URL
@Townman
I don’t normally use Plusnet email. I assume that they are synchronised IMAP servers? When do users connect to squirrel mail and when Roundcube?
Fixes: 388
Re: Strange URL
@Baldrick1 The default is Roundcube, but you can select Sqirrelmail  'basic webmail', from the webmail start page.
Fixes: 480
Re: Strange URL
Thanks @jab1 . I  can see that now. I won’t bother asking why or what the differences are as I don’t use it.
Fixes: 388
Re: Strange URL
Couldn't tell you anyway, I only use it if I get a spam mail, to report it.
Fixes: 251
Re: Strange URL
@Baldrick1 wrote:
@Townman
Hi hairless Richard,
You hint at a common misunderstanding about "webmail".  Webmail is not a separate mail service but is an IMAP email client, running on Plusnet's web servers, which access the same mail server as that accessed by other email clients (both IMAP and POP3) run on PCs, tablets and telephones.
Plusnet offers two web based email clients: Round-Cube (aka advanced) and Squirrel mail (aka basic).
Does that help?
Fixes: 480
Re: Strange URL
@Townman
That makes perfect sense. Thank you,
