Spam filtering threshold
glocal
Greenby's spam filtering is much more aggressive here even though my setup is exactly the same as it was with Plusnet. My spam threshold is set to 3 and it worked well for years. In the headers I see that what makes incoming email look more suspicious is that it is usually sent to [email protected] and my domain host forwards it to [email protected]. That alone adds 2 to the spam score before scoring even starts. Is there a way to tell the spam filter that this forwarding is actually OK?
I know I can increase the threshold on Greenby's website, but that would relax filtering of actual spam.
4 REPLIES 4
PhilipHeyes
Seasoned Champion
Fixes: 27
Re: Spam filtering threshold
In the previous tab of the Greenby portal is Filters
Try adding the email address <[email protected]> as a Whitelist entry.
Fixes: 585
@glocal
Does your domain forwarder support SRS (Sender Rewrite System) ?
If it does, then forwarded mail shouldn't have an increased spam level. If it doesn't then then SPF will fail and you have a good possibility of mail being rejected let alone an increased spam score.
glocal
I believe that's for senders of incoming email. There is no harm in adding my addresses there, so I have and it makes no difference. Most of my incoming email goes to the spam folder with my spam threshold set to 3. Usually there is a header like this:
X-Spam-Flag: YES
 But some messages even have conflicting headers:
X-Spam-Flag: NO
X-Spamd-Result: default: False [4.69 / 3.00];
FORGED_RECIPIENTS(2.00)[m:my_email_address1,s:my_email_address2];
X-Spam: Yes
I think I will switch spam filtering off to see what happens. So far, it only catches legit email anyway.
glocal
Ionos claim they do support SRS (that's 'Sender Rewriting Scheme' I think). And all worked fine for over a decade while Plusnet handled my email. I hardly got any rejections. It all changed the day I was switched to Greenby.
