Server problem?
nozzer
Server problem?
Can't POP into any accounts.
"-ERR Temporary problem, please try again later"
EDIT: Now saying "Socket Error: 10060, Port: 110, Protocol: POP.A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
5 REPLIES 5
Oldjim
Resting Legend
Fixes: 63
Re: Server problem?
me too - just doesn't work
Oldjim
Resting Legend
Fixes: 63
Re: Server problem?
seems to be working now
nozzer
Re: Server problem?
Not for me! Still no access via POP.
bobpullen
Fixes: 316
Re: Server problem?
Some of the collection servers seem to be under high load which may be related. I'll nudge our engineers and make sure it's in hand.
Edit: It was already in hand (ref: 91838 ). I'm told the root cause has been mitigated and load should start decreasing now. Do shout up if you continue experiencing problems.
nozzer
Re: Server problem?
It's happening again! Can't POP any of my mailboxes.
EDIT: It's intermittent. Works for about 30 seconds and then falls over again.
