Server problem?
FIXED- Subscribe to RSS Feed
- Server problem?
03-05-2016 9:07 AM - edited 03-05-2016 9:11 AM
Can't POP into any accounts.
"-ERR Temporary problem, please try again later"
EDIT: Now saying "Socket Error: 10060, Port: 110, Protocol: POP.A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond."
Fixed! Go to the fix.
Re: Server problem?
03-05-2016 9:18 AM
me too - just doesn't work
Re: Server problem?
03-05-2016 9:24 AM
seems to be working now
Re: Server problem?
03-05-2016 9:51 AM
Not for me! Still no access via POP.
03-05-2016 10:14 AM - edited 03-05-2016 10:48 AM
Some of the collection servers seem to be under high load which may be related. I'll nudge our engineers and make sure it's in hand.
Edit: It was already in hand (ref: 91838 ). I'm told the root cause has been mitigated and load should start decreasing now. Do shout up if you continue experiencing problems.
Re: Server problem?
08-05-2016 9:29 AM - edited 08-05-2016 9:32 AM
It's happening again! Can't POP any of my mailboxes.
EDIT: It's intermittent. Works for about 30 seconds and then falls over again.
