Send Error
- Re: Send Error
Send Error
01-10-2026 1:17 PM
Finally get to complain about Greenby email!!!
Sending messages are failing. Get the following
"13:13:39.442: --- 1 Oct 2026, 13:13:39.442 ---
13:13:39.442: Connect to 'relay.plus.net', timeout 999 seconds.
13:13:40.443: >> 220 mail.enmail.co ESMTP ready
13:13:40.443: << EHLO [192.168.178.20]
13:13:40.453: >> 250-mail.enmail.co
13:13:40.453: >> 250-AUTH PLAIN LOGIN
13:13:40.453: >> 250 STARTTLS
13:13:40.453: << MAIL FROM:<xxxxxx>
13:13:40.473: >> 250 2.0.0 OK
13:13:40.473: << RCPT TO:<xxxxxx>
13:13:40.523: >> 550 5.7.1 Unknown sender
13:13:40.563: << RSET
13:13:40.563: >> "
A standard PN email address using Pegasus Mail.
Any thoughts?
Re: Send Error
01-10-2026 1:31 PM
Hi Brian,
Is the FROM address an explicitly configured email address on the Greenby service? Explicit configuration means that either it is a mailbox or an alias for a mailbox.
If the domain side is not @account.plus.com is the domain name hosted by Greenby (can you see it referenced in the portal)?
Re: Send Error
01-10-2026 3:33 PM
@bmc
Is the AUTH step missing from this snip ?
Re: Send Error
01-10-2026 4:08 PM
Thanks for replying.
My apologies for this thread - I posted in a hurry before going out without realising the subject was already covered. I've not been paying attention to email Threads as mine worked!!!
Logging into Greenby and adding my address as an Alias appears to have sorted things.
Re: Send Error
01-10-2026 4:18 PM
It works for most … until one tries to “Send As.., an alias”.
Re: Send Error
a month ago
Is there a thread on this that someone can point me at? I too was using the SMTP server with a Send As address which is now failing with the same error. Trying to fix it! Someone mentioned logging into the portal
Is that a Greenby portal? Again any help in pointing me too that would be appreciated.
Peter
Re: Send Error
a month ago
@PeteW1
The same advice has been posted a dozen or more times in the last 2 days.
Yes use the www.greenby.com portal. Login with the same credentials as are used for the Plusnet Members Center.
Look at post #2 of this thread for what needs to be in place and also what can not be done.
Re: Send Error
a month ago
Thanks I'll check.
Re: Send Error
a month ago
After logging into GreenBy select Emails - Manage
Then select Mailboxes
Then click on the 3 dots to the right and select Alias
Add your email
This worked for me.
