SMTP error 452 (too many recipients in the last hour)
B0n3s
Anyone getting:
SMTP error (452): Failed to add recipient
recipient rejected - too many in the last hour
Not using VPN. Tried via PlusNet IP
Sent very few mails today and never more than a couple of recipients in each message.
Seems to be any address I try. Tried 4 different ones.
Moderator's note:
Title amended to improve understandability
Tags (2)
164 REPLIES 164
B0n3s
Re: SMTP error 452
LOL.
As soon as I post, it's been "fixed"
d-dixon
Re: SMTP error 452
Not fixed here.  I see the same (Force9 email, sending from my Plusnet line) - choice and number of recipients makes no difference.  Bizarrely, the time does - lots of failures if sent at xx:53, xx:57, xx:59, but then everything starts working again a minute later at  xx:00.  So I now have to remember to only send emails just after the hour...
Fixes: 251
Re: SMTP error 452
If you are sending a lot of emails, you will see this behaviour.  There are rate limits per hour and they are different depending on where you are sending from.
d-dixon
Re: SMTP error 452
Thanks - I've sent 3 emails today, each to 1 or a small number of recipients, so that doesn't sound too excessive to me.  Is my quota getting bundled up with a larger user base?
David
Fixes: 251
Re: SMTP error 452
Hi David,
Are you using a VPN?  If yes then the the sum of submissions from all users will be treated a single source.
There are arguments for not using a VPN except for where there is a business need to connect securely to a remote network, as for instance connecting into a corporate network remotely, as though you were on the premises.
There is very little legitimate reason for using a VPN to pretend you are elsewhere, more often than not, their use creates more real problems than they solve.
d-dixon
Re: SMTP error 452
@Townman wrote:
Hi David,
No VPN - just my default, fixed IP address,
David
mavison
Re: SMTP error 452
I have also had a few of these errors this month: 452 <xxx@xxx> recipient rejected - too many recipient in last hour.
In both cases the email was to a single recipient, and was the first sent for at least an hour.
I am also a Force9 user, with static IP, no VPN, sending to relay.force9.net, port 465 with SSL/TLS
B0n3s
Re: SMTP error 452
Ah, not fixed after all. Returned again today. 😐
B0n3s
Re: SMTP error 452
Curiously, around the same time as yesterday. PlusNet load issue maybe?
offscotland
Re: SMTP error 452
I can confirm the time issue of this error.
I tried sending a message every minute from 20:54 and it was bounced each time with the 452 error. As soon as the clock clicked to 21:00 the exact same message sent without a problem....
Fixes: 251
Re: SMTP error 452
What is the A.B.C.x IP address of those users experiencing the issue?
offscotland
Re: SMTP error 452
Tell me how to find that and I'll let you know. I am using Webmail with Windows 7 Professional and have done for many years.
d-dixon
Re: SMTP error 452
For me: 212.56.120.x
offscotland
Re: SMTP error 452
Ethernet adapter Local Area Connection:
   Connection-specific DNS Suffix  . : lan
   Link-local IPv6 Address . . . . . : fe80::9c47:f53a:12c1:a900%10
   IPv4 Address. . . . . . . . . . . : 192.168.1.67
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.1.254
