SMTP Relay
hiwj
SMTP Relay
Is the PlusNet SMTP relay still working? It won't accept any of my connections or send outbound e-mail.
4 REPLIES 4
Fixes: 387
Re: SMTP Relay
What error message, if any, do you get? It is working, BTW
Mav
Fixes: 518
Re: SMTP Relay
Moderator's note(s):
Thread moved from Broadband to Email.
Forum Moderator and Customer
hiwj
Re: SMTP Relay
Done some troubleshooting, and it turned out it was my Exchange Online had started to block all e-mails from that relay server (as it only handles my test/dev site). Have created a rule to always allow these e-mails. Working now. Thanks,
Fixes: 387
Re: SMTP Relay
Glad you sorted it.
