SMTP Authentication
mbeenham
SMTP Authentication
I am currently in Spain and over the last few days sending emails is failing authentication:
S: 535 ...authentication rejected as source IP has a poor reputation
Current IP address is
185.103.149.175
Is it worth reporting this to PN (will I get a useful response?)
11 REPLIES 11
Fixes: 387
Re: SMTP Authentication
It is pointless reporting to PN - it means the connection you are currently using has been abused recently and has therefore been blocked. Is this a mobile one, or fixed?
mbeenham
Thanks for confirming my thoughts.
Its a FTTP connection so maybe I'll try powering off the router for a few hours and see if I et a different  IP address.
Fixes: 251
This is part of the service reputation preservation mechanisms. You could try using a VPN service which has an exit point in the U.K. Alternatively you could use webmail for sending emails.
mbeenham
It is easier for me just to abandon sending via my PN email for now and use my Hotmail or Gmail SMTP until normal SMTP service from PN is resumed. At least receiving email via my PN POP3 account is not affected.
I use a Thunderbird mail client and webmail is too tedious.
A VPN seems unnecessary for this purpose, though I have used it when on shared networks.
Thanks for the comments though.
Fixes: 387
Despite your current blaming of PN, it is not their fault your current IP is regarded as unsafe - it is the fault of whoever misused it previously.
paul_blitz
Fixes: 4
It CAN be PlusNet's fault: recently my brother was unable to send email vial PlusNet's SMTP... from his own home - PlusNet provided - broadband! It seems that his IP had been blacklisted by Spamhaus and others, and despite it being one of Plusnet's own, it got blocked!
Fixes: 387
@paul_blitz I think I understand what you are trying to say there, but, as I (and others) have tried to explain, it is a users fault for misusing the service, not the suppliers or providing it.
Fixes: 251
It does not matter who owns the IP if it gets marked as suspect, it will get quarantined, usually for 24-48 hours.
The ISP is not responsible for the abuse, but rather (in the case of a dynamic IP address) it is down to a previous user.  In the context being discussed, the service being abused need not be one provided by the ISP: the abuse of any service which has a high level of protection and reporting, could cause Plusnet's SMTP servers not to accept connections.
Yes it can be inconvenient to individuals ... but better that than the whole of the Plusnet mail service being laid vulnerable to abuse and thereby no mail service accepting outbound emails from Plusnet's servers for all users.
Sadly it is more often foreign 'players' who most seek to abuse SMTP servers, hence the high level of diligence applied to such inbound connections.
185.103.149.175
some details here https://check.spamhaus.org/results?query=185.103.149.175
HTH
Edit: Click on More Info
paul_blitz
Fixes: 4
If you are sending email from your own personal domain, and can set up a couple of extra DNS records, then you can use someone like MailJet to send your mail. Because you do a 'more secure authentication' with them so that they are 100% sure it's you, they don't block based on source IP address. In fact, I set my brother up to do that when he was blocked by plusnet.
(Unfortunately, if you use a native Plusnet email address, this won't work for you.)
mbeenham
Thank you.
This is the best reply to my original question and if PN continue to block SMTP from my address I might well consider implementing it.
Thank you again.
