Replies to Gmail accounts being rejected
Fixes: 240
Re: Replies to Gmail accounts being rejected
@DrRoy wrote:
I use a hosted domain (myname.com) and use the original email settings both for pop3 and imap
Gmail dislikes both.
This is nothing to do with inbound connections, but only outbound (SMTP) configurations.
quelquod
Setting the SPF record as described solved my problems sending to Gmail too. Many thanks for this tip, been troubling me for a while.
Democracy - 3 wolves and a lamb voting about what to have for lunch!
Richard-261
Thanks.
I applied the above fix and now its all working; I can again send to Gmail addresses.
So what the hell was the enclosed 'support' message about
I hope you are well. I have heard news from our team that the issue is with gmail. We would advise that you open a third party account as we would soon stop offering email services. I had promised to call, however, I am on a training and thought to write to you instead. I am sorry for the inconveniences caused. Have a nice day
Kind regards,
<Redacted>
Moderator's Note: Personal information removed as per Forum rules.
2 strokes good - 4 strokes bad : George Orwell.
Tags (1)
alexpres
More and more, incoming email providers are insisting upon DKIM as well as SPF.
Hosting email has never been an easy game, and the latest implementation of sending & receiving ISPs insisting upon DMARC validation of DKIM & SPF has only made it worse.
Fixes: 357
@Richard-261 I'm glad you have sorted your issue.
As to that support message- I am once again going to tag a member of the Superusers group.
@Townman ?Huh
Fixes: 558
CSC shooting from the hip again!
Fixes: 357
Correct, @MisterW  - I was under the impression they had been 'advised' to be a little less lazy?
Fixes: 558
I think we need to bring back Mand's bat!!!
Fixes: 357
DrRoy
Still no joy this morning - this is my entry.  Mail still goes out as ***@f9.co etc and gmail rejected me again today
The Domain now reads:
Left Field; blank
Type; MX
Pri: 999999
Right Field: please-add-spf-records
It may be I need to add something different on the Right Field
Fixes: 1,652
Hi @DrRoy
I think you were missing a '9'.
I've corrected the entry, so the SPF record should be created in around 6 hours. Smiley
DrRoy
Thanks again
Richard-261
Latest update from the 'Support' people:
At this time there is no time frame yet in place for the email services stopping. However the plans will go ahead eventually. when a date is set you will be notified with ample amount of time to help you set up alternatives for yourself.
Kind regards,
Khamzat Dzhavatkhanov
Fixes: 240
Still misinformed. There are no declared plans to discontinue email services.
Fixes: 357
Sounds like either they (PN) are employing those who wish to damage their employer, or PN have decided on a drip-feed scare campaign. I know which I would tend to believe.
