Replies to Gmail accounts being rejected
FIXED- Subscribe to RSS Feed
- Re: Replies to Gmail accounts being rejected
29-05-2023 9:03 AM
@thekitesociety does this help ? https://support.rocketspark.com/hc/en-us/articles/115010277367-How-to-change-your-DNS-settings-in-1a...
29-05-2023 3:52 PM
Again thanks - the link helped a little although the circumstances are not exactly the same.
I have added an spf record to 1and1 with the PN servers, so hopefully it will kick in when it propogates. I will probably move away from PN servers when ready as I have other bits to fix first 🙂
Jon
29-05-2023 4:01 PM
mxtoolbox is showing an SPF record which looks good to me!
30-05-2023 1:48 AM
I have read the fix and applied to a domain that is on my Plusnet account. I am sure will work but it won't solve my gmail bouncing problems as it is now not my main email account, which is basic Plusnet one, format [email protected]. How do I stop Google rejecting emails for this account.
30-05-2023 5:07 AM
I believe DKIM is automatically enabled for all xxx.plus.com accounts , so Google should not be rejecting from those
30-05-2023 8:37 AM
30-05-2023 4:25 PM
I never use webmail.
Let me explain my situation in more detail. I am on the committee of a local organisation, which body is around a dozen strong, seven of which have Google Mail.. Emails between the membership flow fairly frequently, some requiring responses and it is these that give rise to Google bounces but not every time. If I start new emails those never bounce, it is always my replies to incoming emails that get bounced.
Today I have replied to three emails, only the third one bounced.
Up to now I have surmised that the issue arises because replies to emails contain loads of email addresses and have taken to deleting all embedded email addresses. That often works but far from every time.
Hope this gives you something more to go on.
30-05-2023 4:30 PM
Not entirely.
Attempting to send (reply) to emails using webmail as a diagnostic helps to eliminate a number of potential issues with Gmail.
Do you have an EXACT rejection status please. Gmail has a multitude of unhelpful reasons for throwing away emails sent to free Gmail accounts. Gmail will readily deliver the same email to a paid for Gmail addresses.
30-05-2023 8:08 PM
I am trying to install your fix for missing SPF info to my domain DNS using the PlusNet page which allows addition of custom DNS records.
Your instruction says Type=MX, Priority=999999, Right field=please-add-spf-records.
However, it doesn't say what to put in the 'Left field' box and I can't figure it out.
What should it be?
30-05-2023 8:37 PM
Left field isn't used for MX records , leave it blank
01-06-2023 10:29 AM
Thank you, that seems to have done the trick.
08-06-2023 10:22 PM
@MisterW This appears to have fixed it for me.
Many thanks.
It even fixed email send fails to some business email addresses which I assume have Gmail hidden behind their domain email address.
10-06-2023 11:56 PM
I added this after reading the messages on the forum
| Left field | Type | Pri | Right field |
| mx | 999999 | please-add-spf-records |
to my domain a couple of days ago, but still no joy sending to gmail accounts. I also changed the email security to STARTTLS but then Thunderbird would not download any emails at all.
Any help would be appreciated I have an event coming up soon and need to email 6 people who have gmail accounts, this is a nightmare, seriously thinking of moving away from PN if it can't be resolved.
11-06-2023 7:16 AM
@albagames This gmail issue affects all ISPs - the issue is due to Gmails decision to implement as mandatory non-mandatory RFCs for receiving mail by those who have 'free' mail accounts with them.
11-06-2023 7:38 AM - edited 11-06-2023 7:40 AM
@albagames have you checked that your domain now has an SPF record ?
STARTTLS is a setting for the outgoing server not the incoming.
