Queued outgoing emails
Rob1950
Please can anyone assist,I recently purchased a new tablet and am having difficulties setting it up as the outgoing emails are stuck in the outbox,in what is stated as queued.I have spoken with Plusnet who set it up but  could not resolve this matter and have referred me to the forum.The incoming emails do not appear to be a problem.
Does anyone have any suggestions.
18 REPLIES 18
Fixes: 479
Re: Queued outgoing emails
Moderator's note:
Thread moved from Broadband to Email
Fixes: 251
Hi Rob,
A warm welcome to the forums.  Which email brand are you having problems with?  Plusnet run a number of current and legacy email services.
Rob1950
Many thanks for your prompt reply,not sure which brand,only email is plus.com
Where do I find which brand?
Apologies for not being computer savvy.
Rob
Fixes: 251
@youraccount.plus.com is the core email service.
Check your outgoing server settings. They should be…
SMTP server - relay.plus.net
PORT 587
Authentication required - user name and password the same as the incoming server.
Encryption - STARTTLS
Rob1950
Hi Townman
I amended outgoing server settings as requested and the following replied.
Couldn't verify account server certificate not trusted.
Trust you can help thanks
Fixes: 251
Certificate errors usually occur where the SMTP server has been configured as smtp.plus.net rather than relay.plus.net
Try this diagnostic - in a terminal or CMD window...
curl.exe -v smtp://relay.plus.net:587 -u userID:password -ssl
userID can be any of...
Only post the 235... response.
Note that the line before that is you encrypted userID:password which is readily decrypted and your public IP address is disclosed in the earlier part of the dialogue.
Rob1950
Hello Townman
Apologies unable to find the CMD window on my Samsung A9 Android laptop.
R
Fixes: 251
Oh dear, another android failure!!!
I cannot image the challenges of so many things which are so simple under windows being made overly difficult in other environments ... see build and install curl from source
lahbrannan1
Fixes: 4
Hi @Rob1950
Thank you for reaching out to us.
Please can you confirm if the applicable email is with Plusnet or a 3rd party?
Many Thanks
Lee
Lee Brannan
Fixes: 251
... as per post #4 "... brand, only email is plus.com".
outcast
Aspiring Champion
Fixes: 19
Fixes: 583
@outcast nice find, but curl doesnt seem to work
Rob1950
Hi Lee
I confirm the email is with Plusnet
Rob
lahbrannan1
Fixes: 4
Hi @Rob1950
Thank you for your recent message. I have been unable to find any details on our system with your email address.
Please can you private message us with your account username or address so we can have another look.
Lee
Lee Brannan
