Problems sending to gmail
pvmb
Champion
Fixes: 16
Re: Problems sending to gmail
...But:
Domain Reputation Checker | Check Domain Blacklist Status | Truelist
"Domain Reputation Report for enmail.co
85
Grade: A
Overall Reputation Score
Email Authentication
Score: 40/40
SPF record configured
DMARC record configured
Complete email authentication setup
Infrastructure
Score: 20/25
1 MX record(s) configured"
One of them must be wrong. Either Gmail is wrong or Domain Reputation Checker is wrong (about enmail.com)
njay
The header in post 45 says no spf but earlier in post 38 your username plus.com domain says spf record configured
I would therefore guess the spf record configured for your username plus.com domain doesnt refer to enmail server?
As far as i am aware relay.plus.net is still the correct outgoing server for all plus.com email even when migrated.
pvmb
Champion
Fixes: 16
@njay
"The header in post 45 says no spf but earlier in post 38 your username plus.com domain says spf record configured"
From Message 45 - From Gmail wrt enmail.co
BAYES_SPAM(2.24)[90.22%];
DMARC_POLICY_QUARANTINE(1.50)[enmail.co : No valid SPF, No valid DKIM,quarantine];
From Message 46 - From Domain Reputation Checker wrt enmail.co
https://truelist.io/tools/domain-reputation-checker
85
Grade: A
Score: 40/40
A seeming contradiction between Gmail and Domain Reputation Report. Although Gmail uses the term "No valid SPF" and "No valid DKIM"
Message 38
Domain Reputation Report for <My Plusnet User ID>.plus.com
70
Grade: B
Score: 15/40
No DMARC record found
AND
Domain Reputation Report for plusnet.com
55
Grade: D
Score: 0/40
No SPF record found
i.e. 'My' Plusnet email account domain/subdomain is here reported with a higher reputation (curiously the same as greenby.com) than Plusnet's own domain!
Though, how is it possible for Plusnet email to have operated seemingly successfully for years if it did not have a correctly configured email domain? Has something been changed? Is any of this valid? What is actually the case?
I do wish someone who really knew about all this would have a look or comment.
pvmb
Champion
Fixes: 16
BTW - Although relay.plus.net is not what Gmail was reporting on in my bounced email message.
Domain Reputation Report for relay.plus.net
25
Grade: F
error
Score: 0/40
No SPF record found
Infrastructure
Score: 0/25
No MX records found - domain cannot receive email
Blacklist Status
6/6 clean
Checked 6 major blacklists
✅ Not found on any blacklists
warning
Domain Health
Score: 15/25
check Appropriate domain length
check Reputable top-level domain
X Domain not configured for email
 Recommendations to Improve Reputation
Configure SPF record to improve email authentication
Add DMARC record to protect against email spoofing
Configure MX records to enable email receiving
Configure email services to establish domain legitimacy
pvmb
Champion
Fixes: 16
I have an unfortunate theory about email delivery failures from Plusnet/Greenby email accounts. Could the local experts on such matters have a quick look and (hopefully) dismiss it all as "nonsense!".
(I was going to post it before but results above seemed incompatible with the idea...)
It's over the question of 'What is an email domain?'
If a lot of users have a email accounts with 'MailUs.com', then their email addresses are usually of the form:
[email protected]
[email protected]
[email protected]
[email protected]
But what if their MailUs email addresses were instead like this:
[email protected]
[email protected]
[email protected]
[email protected]
In the former case all emails would originate from a single email domain. A single email domain with a presumably correctly configured SPF, DMARC, DKIM etc. In the second case would there not be as many email domains as email users? These 'email domains' would likely not have any individual SPF, DMARC, DKIM settings.
njay
With email addresses ending @userid.plus.com each userid is essentially a different subdomain of plus.com
What i suspect based on your lookups is that spf records are only defined for each subdomain i.e. userid hence why when you check you own userid plus.com it says spf record configured
In terms of enmail.co whilst tool comes back as saying it has spf record this doesnt necessarily mean its valid for
Plus.com email addresses. I.e. both gmail and tool can be right.
Have you tried reverting to relay.plus.net as outgoing server and sending to gmail?
PhilipHeyes
Seasoned Champion
Fixes: 21
The SPF & DMARC & DKIM relate to the DNS records for email address.
Plusnet hosted SMTP : relay.plus.com has become a nightmare for us of triggering false spam rejections before transmission leading to password changes.   But it remains the only SMTP that sends DKIM signatures,   SPF & DMARC both Pass too.
The Greenby SMTP server and there are several to pick from need to be chosen with care to avoid Credential rejection or to avoid Certificate errors.   None of the Greenby SMTP appear to have enabled DKIM Signatures yet, this could be an issues with Gmail & iCloud,
rogermhunt
The two emails that I sent yesterday evening to two different gmail addresses were both received successfully by the recipients. So for me at least, it seems that Greenby has finally solved the problem.
For info if it helps, my outgoing SMTP server is set up as  mail.enmail.co
pvmb
Champion
Fixes: 16
I am only using the Greenby webmail client and don't use my own email client software, so cannot change the SMTP mailer being used. I did wonder myself if using a Greenby email domain host to send emails with a Plusnet based email domain name could be behind the issue, but surely this would have been taken into account in setting up the new system?
I may look into all this stuff a bit more later on - not that I necessarily understand it very well!
I can't understand why, if there is a known cause, it has not simply been sorted out by now - unless it isn't simple.
pvmb
Champion
Fixes: 16
Snap!
My repeat test mail has been delivered at Gmail - confirmed by Delivery Receipt. Interesting to look at the headers for the receipt email:
X-Spamd-Result: default: False [1.30 / 8.00];
R_SPF_NA(0.00)[no SPF record];
PhilipHeyes
Seasoned Champion
Fixes: 21
Why interesting ? What can we learn from that small clip of the email header ?
