Phone only receiving e-mails with connected to home wifi
Digsy
Re: Phone only receiving e-mails with connected to home wifi
Changing the port to 587 seems to have fixed the issue.
Maybe its time to remove port 25 from the FAQ? It worked fine for me right up until a few days ago.
Anyway, thanks for the pointer.
outcast
Aspiring Champion
Fixes: 19
@Townman  is it worth 'escalating' that suggestion ?
Fixes: 240
@outcast
Please see my PM - I'm working on a different solution!
Port 25 should NEVER have been included in the guide.  Call it pedantry, but for email client message SUBMISSION it is technically wrong.  The fact that using the MX message RELAY port might work does not mean it is correct.  I just do not understand why users persist in using it.
Historically connections to 'off-network' servers on port 25 were firmly blocked.
The fact that port 25 is wrong and the encryption reference to STARTTLS is confusing has been raised several times over a long period ... and it remains unchanged!  @James_B
