Phishing Emails
CW84
Re: Phishing Emails
I can only see one email address in webmail and that's the one the email was sent to. It shows a few kbs of mail in the inbox and nothing in the other folders (deleted, sent etc). I can't see any way of getting web mail to display either the other email address I use or the overall mailbox, by which I mean the one that is [email protected] as opposed to [email protected]. I never access webmail, I use Thunderbird if that sheds any light?
Is this a problem with plusnet as opposed to anything  sinister, is it safe just to ignore it (my emails are stored on my PC by Thunderbird, I wasn't aware that Plusnet stored them too, I'd rather they didn't but I can only access the main address so I guess I can't change this.
Thanks for your help
Fixes: 250
Re: Phishing Emails
Webmail only gives you access to the mailbox you logged into.
You can log into each mailbox using each mail box's individual identity...
Within the user portal use MANAGE MY ACCOUNT - configure emails to find out all of the mailbox names you have configured on the account - it would not surprise me if there ones you have forgotten about.
Did you check the 'manage folders' option to ensure that there are no hidden folders?
CW84
Re: Phishing Emails
Thanks to all for help, I am now reassured that the original email was legit. I still can't find 'personal settings' 'Folders' etc. but I think I'll give up on that for now.
Fixes: 250
Re: Phishing Emails
Bottom left hand corner of the Webmail screen.
wphil
Re: Phishing Emails
Same here.
Paypal - notification of some purchase.
Microsoft  - purchase of microsoft 365
Frustration is that plusnet server is stopping me reporting them.  Spotting them when I try to forward but not when sending them to me!  This is part of the error I get
The mail server responded:  n0qLtVvnYSSpfn0qMtp9wz message rejected due to spam or virus.
Never had this before;  I always report phishing to appropriate organisation.
What to do plusnet?Huh
Wphil
