Outgoing server settings,
- Re: Outgoing server settings,
Sunday
I'm having issues sending emails from Thunderbird on my PC, but the same settings work via Gmail on my phone.
I've tried every setting I can find for a freenetname based account I can find and the phone is set as;
smtp.freenetname.co.uk
port 587
security none
Has anyone else got a setting for Thunderbird that works?
Sunday
what error is Thunderbird reporting ?
yesterday
"Sending of the message failed.
An error occurred while sending mail. The mail server responded: Unknown sender. Please verify that your email address is correct in your account settings and try again."
That's the pop up box with the error
21 minutes ago - last edited 20 minutes ago
The email address that you are sending from is not configured as either a mailbox name or an alias.
The sending address is shown in Thunderbird as the email address in the Default Identity settings.
Check that the email address is set there as [email protected] ( the same as the phone )
