Move to Greenby and pop email
eeyore033
Re: Move to Greenby and pop email
This is what has worked for me for 20+ years on PlusNet and still successfully retrieving messages this morning on Greenby post-migration.
For incoming POP3, I specify the following settings to retrieve emails from Free-online:
Address: mail.free-online.net
Port: 110
UserID:  my username for my Free-online account
Password:  my password for my Free-online account
Good luck!
ClaireS
If I try to change passwords for mailboxes on Greenby I just get "Whoops! Error: Network Error".
Also, the latest AI bot at Greenby says instead of entering my username as the previous mainuser+subuser format, I should enter the full email address as my username. Still not working.
ClaireS
Regarding changing individual email account passwords, how do I do this? I can see the Change Password option under the three dots, but regardless whether I enter a password of my choice (completing all the green bands under the password strength guide) or choosing one of their randomly generated passwords, I just get "Whoops! Error: Network Error".
Greenby support is non-existent. All you get is an AI bot (who granted is very personable and eager to help) but at some point it always gets to "I'm transferring you to an agent, they will be with you shortly" and that's where the chat ends. Not one agent has joined one of my various attempts at a support ticket since Friday.
I don't know what to do. The days are counting down on my 30 day trial period and I can't get mail to download.
Any help or advice would be welcome at this stage.
Fixes: 240
@plusnettony is this something Plusnet can escalate please?
plusnettony
Fixes: 56
Yes, I'm just about to raise a couple of things.
Would it be possible though, for you to supply me with a screen shot? Might make it easier to explain. Thanks
 Tony T
ClaireS
Okay I'm going to sound really thick here, but how do I attach a screenshot?
(I have the screenshot but can't see an option to attach anything)
Fixes: 357
@ClaireS Are  you using a mobile device?
ClaireS
Yes. Unfortunately this whole shenanigans happened while I was on holiday so I'm stuck with just my trusty 7 year old iPhone.
Fixes: 357
In that case, select the 'desktop site' from the drop-down menu - the 'hamburger' or three dots.
ClaireS
Great, thanks for the advice re desktop site.
Ok, here is the screenshot of
what happens when I try to change the password of one of my mailboxes. IMG_5432.png
Tags (1)
plusnettony
Fixes: 56
Thanks  - I think we've got the bottom of the issue now, are you able to re-try?
 Tony T
ClaireS
Hi there.
Sadly I still get the Whoops!Error: network error message when I try to change my mailbox password.
Which issue did you get to the bottom of? Emails downloading to phone or password reset?
Thanks.
plusnettony
Fixes: 56
Logging into the email.
I'll re-raise the whoops error when I can replicate it.
 Tony T
plusnettony
Fixes: 56
Re: the changing password error, can you confirm step by step what you do?
I've looked at
https://greenby.com/profile/account-details
3 dots
Profile
Change (next to password)
Password reset email sent (Appreciate that won't work if you can't get emails)
Enter code
but haven't managed to replicate.
 Tony T
ClaireS
Hi there
It's not my Greenby profile password that needs changing - I have that and can view webmail (so I can receive emails - just via webmail, not via pop to my phone).
It's the individual mailbox passwords that I can't reset:
Menu: Email
(See list of mailboxes)
Select three dots to the right of the mailbox I need to change the password for
Click Change Password
Enter the password
Click Change Password button
"Whoops! Error: network error".
This happens whether I enter a password of my choosing that meets the strength criteria, or if I use Greenby's random password generator.
