Mime format
drj
Mime format
This is a continuation of a locked topic query which was never resolved.
I get some emails that report:
This is a message in Mime Format.  If you see this, your mail reader does not support this format.
Since I'm now using webmail most of the time I find it inconvenient having to download these to OE in order to read them. I've tried forwarding within webmail as I suggested I would in the previous topic but that doesn't work neither does looking at them via Squirrelmail.
Is there any way of reading them through webmail?
16 REPLIES 16
drj
Re: Mime format
Update - I've tried "Forward as attachment" at which point the email is converted to a .eml file - which can then be opened and is readable.
However it appears to have been corrupted in the process - check out the spurious examples of "=" on the attached screenshot - and clicking on the url doesn't work (Page not found - Sorry, the page you requested was not found - Please check the page address and try again.) which suggests it's corrupted too.
RPMozley
Fixes: 13
Re: Mime format
This one is usually caused by either something missing or incorrectly formatted in the email header. Post up the headers, removing or obscuring any personal info, for people to take a look at it or alternately send a pm.
That's RPM to you!!
drj
Re: Mime format
Return-path: <bounces+182935131##_@edigitalresearch.com>
Envelope-to: [drj's plusnet address]
Delivery-date: Fri, 21 Dec 2012 17:32:36 +0000
Received: from [212.159.9.108] (helo=avasin10.plus.net)
    by inmx20.plus.net with esmtp (PlusNet MXCore v2.00) id 1Tm6Sa-0002r0-Io
    for [drj's plusnet address]; Fri, 21 Dec 2012 17:32:36 +0000
Received: from mailex.mailcore.me ([94.136.40.61])
    by avasin10.plus.net with Plusnet Cloudmark Gateway
    id eHYa1k0021KAJUm01HYcxP; Fri, 21 Dec 2012 17:32:36 +0000
X-CM-Score: 0.00
X-CNFS-Analysis: v=2.0 cv=bueS8jmi c=1 sm=1 a=OyMLhrVIYKQdB+tsvLWZQA==:17
    a=q12e_xdeQZoA:10 a=JsY51RG-bMYA:10 a=toe0z9XoAAAA:8 a=BXk0pPJ-sSAA:10
    a=KmVMel8GAAAA:8 a=YIdeN2CtOCBM_H8tSjIA:9 a=wPNLvfGTeEIA:10 a=9Wo_25z3w9oA:10
    a=0p89r6P3SnMA:10 a=Awv00vs-AAAA:8 a=QEXdDO2ut3YA:10 a=0BDeWViGR5WQk-hm:21
    a=_tPHiTsyqyMMZGcD4LIA:9 a=HXjIzolwW10A:10 a=Sf_gFPzhefAA:10
    a=82LjNw-041XiKApq:21 a=fRoFPgpQfhOevOQC:21 a=kWJWkfjmwvxWFaRi:18
    a=Rno0-rHjolZeDAq5wBQA:9 a=OdNCU1nZAB1OT7u-:18 a=Excol4T00OSRofKgfmIyDw==:117
Received: from mail1.edigitalresearch.com ([46.236.9.22])
    by mail6.atlas.pipex.net with esmtp (Exim 4.71)
    (envelope-from <bounces+182935131##_@edigitalresearch.com>)
    id 1Tm6SX-0008Aq-IX
    for [drj's email address]; Fri, 21 Dec 2012 17:32:34 +0000
Received: from scripts1.vm.edigitalresearch.com (scripts1.vm.edigitalresearch.com [192.168.100.207])
    (using TLSv1 with cipher DHE-RSA-AES256-SHA (256/256 bits))
    (No client certificate requested)
    by mail1.edigitalresearch.com (Postfix) with ESMTPS id 5FD86163208
    for <[drj's email address]>; Fri, 21 Dec 2012 17:32:33 +0000 (GMT)
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/simple; d=edigitalresearch.com;
    s=default; t=1356111153;
    bh=On4TwPlYZtxE0zeJXjt8nExykOl8UV78F5fUj8vhGW4=;
    h=To:Subject:From:Reply-To:List-Unsubscribe:Date;
    b=b1FwprIix7xUYxIoMel/tfPUbUu9LIPZZnwcVLr1qUALQHoZ9p1gzhfD29QO+Fuif
    Nm7fOOennxWEOQ3pxsRjEpj6KEkTIl27cILv4Yatx13bPWBLBGM5T2f4kWJG/Tj2oz
    3mEKdpqnUaykQGhu0yXbPLSitt1SX7OTY8udIdO0=
Received: by scripts1.vm.edigitalresearch.com (Postfix, from userid 48)
    id 5876316021F; Fri, 21 Dec 2012 17:32:33 +0000 (GMT)
To: <[drj's email address]>
From: "Auto Trader Team" <info@edigitalresearch.com>
Reply-To: "Auto Trader Team" <info@edigitalresearch.com>
X-Mailer: eDigitalResearch.com Mailer/[PHP/4.1.0]
Content-Type: multipart/alternative; boundary="=_c8cbd0c4ac88cd48032501325bf98f87"
Message-ID: <edigital-822-1356111153-182935131@bounces.edigitalresearch.com>
List-Unsubscribe: <http://hub.edigitalresearch.com/unsubscribe/index/182935131/299071200?vault=_&amp;action=unsubscribe>
Date: Fri, 21 Dec 2012 17:32:33 +0000 (GMT)
X-PN-Virus-Filtered: by PlusNet MXCore (v5.00)
X-PN-Spam-Filtered: by PlusNet MXCore (v5.00)
Subject: Auto Trader Research
NedLudd
Re: Mime format
drj
Re: Mime format
Yes but with respect that's irrelevant to my question which is how can I view these via webmail - and if I can't why not? If Outlook Express can handle these without a problem why can't an up--to-date webmail platform?
kmilburn
Re: Mime format
A leading question,  do you have the following option enabled?
  Personal Settings -> Displaying Messages  ->  Display HTML
Jaggies
Re: Mime format
Does the mailing list give you the option to receive messages in plain text rather than rich text/HTML?
RPMozley
Fixes: 13
Re: Mime format
Ah, just as I expected. Email header is missing the important MIME-Version tag in it.
I had a similar issue from another email newsletter awhile back. Thankfully after conversing with their web guy I managed to get it all fixed up.
So my advise to you would be to contact the email provider and tell them to make sure they have "MIME-Version: 1.0" in their email header. This tag is a requirement for all HTML messages.
That's RPM to you!!
drj
Re: Mime format
Thank you - I'll try!
drj
Re: Mime format
@kmilburn + @Jaggies - thanks but the settings are already on HTML display - only the Auto Trader ones weren't displaying - all others are OK - hopefully the sender can resolve.
Jaggies
Re: Mime format
My point was if they can't sort out the MIME Version issue, if you have the option to receive the emails from the list in plain text instead of Rich Text/HTML you won't have this problem. Your own display settings are irrelevant.
drj
Re: Mime format
Quote from: Jaggies
OK - so you mean if I have the option to receive the emails from Auto Trader in plain text format? Is that what you mean by "the list"? However it's not a forum. I'm registered with Auto Trader and they periodically (several times a month) send out survey invitations. It's those I'm having trouble with since I can't reach the survey because currently Plusnet webmail is corrupting (i.e. not showing properly) the URL link. There only appears to be an "unsubscribe" link in their emails, not a "settings" link which might give me the option.
NedLudd
Re: Mime format
As the article that I linked to says, it is often because the sender is not doing something appropriately. It is Auto Trader that need to change, not you!
Geoff,
York.
drj
Re: Mime format
I realise that now thanks.
