Mail delivery to recipients taking 5hrs plus
FIXED- Subscribe to RSS Feed
- Mail delivery to recipients taking 5hrs plus
Re: Mail delivery to recipients taking 5hrs plus
14-03-2019 6:41 PM
Can anyone explain this "non-existent" email security?
14-03-2019 9:41 PM
This is a thread about delays and non-delivery to Gmail, so probably best to look up security issues separately on the relevant threads, of which there have been a few over the years. Try searching for Plusnet TLS/SSL.
16-03-2019 9:37 AM
Hello.
Mail from my plusnet box sometimes takes 3 or more days to arrive in my gmail box, this delay started a week ago.
Email header suggests there was a 3 day delay between avasout07.plus.net -> mx.google.com
JonoH, I guess it's an issue between plusnet & gmail. Do you know if a fix is round the corner?
Thanks.
16-03-2019 10:25 AM
Hi Brian,
A warm welcome to the forums.
This issue has been going on for a long time, ever since Gmail changed something on their email service which they have not been clear about. It only impacts emails sent from @Username.plus.com email addresses to free @gmail.com addresses. If the email is sent...
- From a private domain name hosted on your Plusnet account - there is no issue (note domain hosting is now a legacy feature)
- To paid for Gmail addresses - there is no issue
- To the @googlemail.com (or @googlemail.co.uk) aliases for @gmail.com addresses - there is no problem
The issue is NOT anything to do with SENDING email to Gmail.com, but with that service ACCEPTING send attempts.
Gmail support information is not exactly helpful in respect of these symptoms; it suggests doing things which are very evidently not required and when attempted to be implemented caused wider problems. Gmail support have not responded to enquiries made by a large number of people on their support forums.
In the meantime other measures are being investigated.
16-03-2019 10:29 AM
Many thanks for the info Townman, most prompt & helpful.
Cheers
16-03-2019 11:09 AM - edited 16-03-2019 11:10 AM
Hi Brian,
You are most welcome - if it helped, please feel free to give a thumbs up.
Your quest prompted me to return to a recent series of tests I ran - on the 12th March I sent five test emails to both a free Gmail account and a paid for Gmail account...
- The paid for account received all five emails instantly
- In respect of the free Gmail account
- #2 arrived immediately (14:31 time of sending)
- #1 arrived over 2 hours later (16:58 )
- #4 arrived another 22 hours later (+1d after sending at 15:05)
- #3 arrived another 40 hours later (+3d after sending at 07:04)
- #5 arrived another 20 hours later (+4d after sending at 03:06)
Though some users have reported that some emails are never delivered, I have not seen that, but as shown above some very long variable delays. There is evidence that Gmail resets its deferral delay; the above variability suggests having hit 40 hours, the nest delay is shorter. I have also seen evidence that sending another test batch (for example between #1 and #4 above being received) sets a new delay sequence similar to the above.
Manually running tests is a bit of a pain … I might look at setting up some automation to generate batches of tests … but then that would look like spamming … the very thing Google put these (undocumented) measures in pace to stop!
16-03-2019 3:19 PM
Good luck on your RnD, Townman & thanks for taking an interest.
I'll admit, I didn't know you could have a "paid" Google email account but I've no intention of handing any dosh over to
those guys as I figure they have quite enough money already.
My boss sends his emails to both my Plusnet & Gmail boxes, they pop through promptly and ok on both. His mailbox
is doubtless linked to the Company website, so probably pays extra for that. Hos provider is BT.
This old twit has now set his phone up to send/receive using my Plusnet mail box so this problem with gmail is
circumvented.
Thanks again
06-04-2019 7:35 PM
I've got the same issue - I do have a plus.net account but I use gmail because it's easier to pick up my mails anywhere with a cloud based service . My husband uses plus.net. My plus.net account is virtually dormant I think.
This issue has been driving me nuts because we email eachother often regarding various things and his mails can take anything from 2 hours to 2 days to reach me.
My husband used to be in IT and agrees it's a google issue not a Plusnet one and as Google don't reply there is nothing I can do from that end.
I did contact Gmail support about it and never received an acknowledgement or reply. My suggestion was that if google are going to apply a "? - not authenticated" token to an email address, Gmail users ought to have the option to mark known addresses as a 'safe sender' (and there should be code in place to ensure that once marked by a user as a genuine safe email address, there are no longer delays. But there is no option to do that.
My other half is of the opinion that it's my problem not his...(true).
Having read through a lot of this thread...if I tell him to send to me as xyz@googlemail.com rather than gmail.com, is the general consensus that this might help the email reach me quicker?
06-04-2019 8:44 PM - edited 06-04-2019 8:45 PM
It is certainly worth trying.
06-04-2019 8:59 PM
Has there been an update from Plus Net recently?
06-04-2019 9:45 PM
I can certainly confirm that email sent to X@googlemail.com rather than X@gmail.com seems to suffer no delay. When replying to messages from gmail.com addresses, I do have to remember to edit the replyee's address so as to change the gmail.com component to the googlemail.com version, otherwise my reply would likely suffer delay. Needless to say, I've been too hasty on a few occasions and forgotten to make that change 🙂
07-04-2019 9:14 AM
Mr Sirjestalot.
Well done, sir. Confirmed your results.
Test message 1 from my Plusnet box to my @googlemail.com box arrives fairly instantly.
Test 2 using Plusnet to my @gmail.com box is delayed.
Many thanks!
07-04-2019 11:09 AM
yup. that works! So for sending mail to gmail contacts the work around seems to be to use googlemail address. When replying to gmail users, plusnet users will need to edit the reply address from gmail to googlemail. It doesn't help everyone but it will resolve the issue for many...thanks all
08-04-2019 9:55 AM
Not really as there's very little new information other than we're working on another solution that's currently in testing.
08-04-2019 11:17 AM
I edited my address book (I use Mozilla Thunderbird) and changed all the 'gmail.com' entries to 'googlemail.com', so that new messages to an address book entry are always 'safely' addressed, but replies do of course still need to be edited as required. Provided that Google don't pull a fast one and close down the googlemail.com domain, I expect I'll keep to this arrangement.
