Mail delivery failed: blocked using Spamhaus
Boink
Hi, I can't send email to hotmail accounts, getting the following error:
Diagnostic-Code: smtp; 550 5.7.1 Service unavailable, Client host blocked using Spamhaus
24 REPLIES 24
Marsh
Fixes: 41
Re: Mail delivery failed
Hey @Boink,
Could you please let us know if your getting this error on our webmail website or while using a third-party email client for our email service?
Josh
Boink
Third party mail client (Thunderbird on Windows PC)
Managed to get my IP unlisted (for now...) by following their link to Spamhouse.
I did not abuse the email system, seems they don't like non-microsoft clients...
Peter123
I have started to get this error too. Just recently in the last week or so.
Frome the SpamHaus website, I get
Outbound Email policy of Plusnet Plc for this IP range
It is the policy of Plusnet Plc that unauthenticated email sent from this IP address should be sent out only via the designated outbound mail server allocated to Plusnet Plc customers. To find the hostname of the correct mail server to use, customers should consult the original signup documentation or contact Plusnet Plc Technical Support.
I have not changed anything here!!   What should I set the "outbound mail server" to be?  I'm using Thunderbird on Debian.
Regards,
Peter
Fixes: 246
A few questions...
  1. Are you connecting over a Plusnet supplied internet service?
  2. Are you using a VPN service?
  3. Are you sending from [email protected] ?
  4. Are you using relay.plus.net as the SMTP server ?
  5. Is the outbound service configured to require username & password?
  6. What is the A.B.C.x part of your external IP address ?
  7. Who is the recipient domain ?
That BL should only apply where a user is attempting to run their own SMTP service on they home IP address.  something is not quite right here, hopefully answers to each of the above questions should help to better profile the issue.
Peter123
Hi TownMan,
Thanks for looking at this. Re your questions;
1) Yes
2) No
3) Yes
4) My email server settings say 'POP Mail Server' and mail.plus.net
   (These have not changed for many years)
5) Yes
6) My IP address is set dynamically each time I start the router.
    Right now its 87.114.51.77, yesterday I was using 91.125.55.122  and 146.66.42.104
    with the same result.  All these IP address are on the SpamHaus Policy Block List (PBL)
7) I am blocked from sending email to [email protected]
   I first noticed this problem on 26th Feb. I could post to the mailing OK on 21st Feb
   I'm not aware of any issues with other recipients
So what changed between 21st Feb & 26th Feb ?
Regards,
Peter
Fixes: 580
@Peter123  those are the incoming server settings, @Townman  needs to know if the outgoing server is set to relay.plus.net ?
All dynamic IP addresses are on the PBL. It indicates that mail should not be sent directly from those IP addresses. Providing your outgoing server is set to relay.plus.net then it should not be a problem.
It seems as though that destination mail server is using the PBL incorrectly ( its not unheard of! )
Fixes: 246
@Peter123
@MisterW has probably articulated well the issue - bad use of PBL by the receiving domain.  If your emails are being delivered successfully elsewhere, then the issue must be within the receiving email service.  As noted - it is far from being unknown!
Peter123
Hi MisterW,
I checked the outgoing server and it is set to relay.plus.net. So while there "should not be a problem",
there is.
The FreePascal folks say the problem is that PlusNet should not be sending their own IP addresses to the PBL.
Regards,
Peter
Fixes: 580
@Peter123
I'm sorry but they're wrong!
This https://www.spamhaus.org/blocklists/policy-blocklist/ explains the use of the PBL
The PBL detects end-user IP address ranges which should not be attempting to directly deliver unauthenticated SMTP email to any Internet mail server. All the email originated by an IP listed in PBL is expected to be submitted - using authentication - to a SMTP server which delivers it to destination. The SMTP server can be either supplied by the ISP connecting the IP or by an external mail service.
You are NOT sending email directly from your IP address, it IS going via the ISP ( Plusnet ) mail server. Hence Freepascal should NOT be checking your IP address.
One further question, though ? the above PBL policy does state 'is expected to be submitted - using authentication'  but I'm not sure that is a definite requirement.
Is your email client configured to use authentication on the outgoing (SMTP) server ? you should use your PLusnet account name and password.
Peter123
While I am only seeing isssues with the FPC mailing list, 2 secs on Google searching for SpamHaus and PlusNet
reveals many reports of this issue with PlusNet email, most with no resolution.
However I did find one fix, when a user was blocked from Microsoft 365.
The thread is from 4th Nov 2022. (First page of Google results, per above)
[BobPullen]
I've assigned you a static IP. You'll need to disconnect/reconnect for it to be applied. For verification purposes, it's in the 84.92.0.0/16 range.
[GMC]
Thank you Bob for setting up the static IP.  I can confirm that having a static IP has solved the problem although I appreciate that there was something strange going on with the dynamic IP addresses flagging.
Is there any chance I could be assign an (unblocked) static IP address?  Based on GMC's experience, that should fix the issue.
Regards,
Peter
Peter123
Hi MisterW,
My last post crossed with yours. A key peice of missing information here, is who changed what between Feb 21st & Feb 26th? Any ideas?  I'm not aware of anything significant at my end.
Re email settings, I'm using Thunderbird, and Security Settings are
[Connection Security] SSL/TLS
[Authentication method] Normal password
Regards,
Peter
Fixes: 246
Inbound is TLS/SSL
Outbound is STARTTLS
However, if you have the outbound settings significantly wrong, you'd not be able to send at all.
Static IP address are no longer available and that "resolution" was not a fix, but an avoidance measure.  The action by this mail hosting service is totally inappropriate.
Historically static IP addresses DID permit users to run their own email servers, in which case those IP addresses were permitted to send (MX to MX) email messages direct.  Such is not permitted on dynamically allocated IP addresses.
The 'rub' here is that you are NOT sending email direct, you are sending it via PlusNet's official relay service and thus there is no applicability of this block policy.  This is not the first time we have seem the total misunderstanding of the application of that block list.
The receiving party is wrong here.
Fixes: 580
@Peter123 it won't be anything at your end and all dynamic IP addresses have ALWAYS been on the PBL. So unless one of the plusnet mail servers has got itself on the PBL (very unlikely and if it has then the networks team will have proactively requested it to be removed!) , the change will be at the receiving end.
Static IPs are not on the PBL (well not if requested to be removed) since its legitimate for static IP users to be running their own mail server. However static IP's are no longer available to customers who don't already have them.
The fact that your email to other destinations works fine does tend to confirm that the problem is at the receiving end.
I have my email with a third-party supplier, if you like, I can PM you an email address to send a test email to. Then I'll check the headers to see if there's anything that might indicate a problem.  Let me know if you'd like to try that ?
Peter123
Outbound was None. I've just changed it STARTTLS, and will check results.
It was probably set to None for at least the last ten years!
Sadly, no change. I'm still blocked!
Diagnostic-Code: smtp; 554 5.7.1 Service unavailable; Client host [84.93.230.227] blocked using sbl-xbl.spamhaus.org;
