Madasafish missing?
Fixes: 251
Re: Madasafish missing?
There is a network issue under investigation.
mw25
I have the same issue with my madasafish.com email, unable to receive or send emails.  No emails received since 14:30 yesterday (Thursday).
Any update on this problem?  Is it being investigated?
Fixes: 251
As above. No and yes.
Fulltopuk
Looks to have been fixed now.  🙂
Fixes: 251
Resolution is still in-flight.  DNS changes need to promulgate all of the DNS server instances.
Both madasafish.com and www.madasafish.com need to update everywhere.
Riverside
Looks like it's up and running now. The webpage is back and mail is flowing again.
Fixes: 251
Just ran some more tests - can connect over PN network to the MAAF website (www.madasafish.com) but not when connected over EE mobile.
Looks as though the DNS promulgation is still a work in progress.
Woldsman
My Outlook has just started being able to connect what appears to be reliably to get my Madasafish domain Pop 3 emails. Thanks again Townman. Your intervention on this issue has saved me a really big headache!  Don't ever underestimate the good and the difference that your efforts make for others!  I'm so grateful.
dor
Confirm now working - downloading POP3 emails to Thunderbird. Thanks Townman for your help and intervention.
Sprat
Email has been working normally overnight and earlier this morning.  Webmail seems to be working normally now but email apps in iOS & iPad haven’t been able to connect & download messages again for the past hour or so.  Seems there is an ongoing problem….
Fixes: 251
@Sprat
A warm welcome to the forums.
That could well be the common issue seen with iPhones & iPads (iOS issue).  Try unloading the email application and then retry.
Sprat
Thanks @Townman ,
My email seems to have sprung back into life again now, on it’s own…. but if I get more problems I’ll try your suggestion.
DH54
Thanks for all your help - really appreciate it!
