Legit mailrelayed from non SPF hosts?
Fixes: 251
Re: Legit mailrelayed from non SPF hosts?
I don't ever use authentication with relay.plus.net.
I suspect that will give rise to ambiguity over which servers are used.  I await an answer on clarification.
Regardless, that SPF configuration should do what you need.
