Leaving Plusnet
Spike581
Leaving Plusnet
Hi
Huge apologies as I suspect it had already been asked and there are a lot of threads to try and find the answer
After lots of years with Plusnet it looks like will be leaving when contract is up in 2 months purely down to cost sad to say
If I leave what happens to my email accounts?
Do they simply stop working or as they are serviced by Greenby they carry on active?
Many thanks
4 REPLIES 4
Fixes: 387
Re: Leaving Plusnet
@Spike581 If your email is now with Greenby, it will carry on, but you may need to modify some server settings.
plusnettony
Fixes: 74
Re: Leaving Plusnet
Firstly, I'm sorry to see you're wanting to leave.
If your Email has already migrated to Greenby, it will carry on as normal.
 Tony T
Spike581
Re: Leaving Plusnet
Thank you Tony
Spike581
Re: Leaving Plusnet
Thank you John
