IMAP woes
- IMAP woes
IMAP woes
26-03-2016 5:51 PM
My wife is trying to use IMAP to access her PlusNet email on her Windows 10 laptop. The problem is that out of about 30 folders under her Inbox, the email client is only showing about 5. We have tried setting up the account in 3 different email clients, Windows 10 Mail, Outlook 2016 and Mailbird. All behave in the same way and with the same folders.
I have deleted and recreated her mail profile.
I've tried changing the root folder (\, inbox, Inbox, INBOX)
I've tried finding the folders in the IMAP folder management dialogue
Nothing.
If I manually create a folder of the same name in the email client, all of the correct messages show up in that folder, but as soon as I send/receive the folder disappears again.
This also happened on an older Windows 8 machine.
Microsoft have examined the machine and can find nothing wrong with Outlook. They believe there is something in the PlusNet IMAP service which may not be fully compatible with modern clients.
PlusNet have been less than helpful, stating that their responsibility stops at Webmail (which does work). They won't even tell me if they can see any difference between the folders which work and those which don't.
Does anybody on here have any idea what could be causing the problem and how to resolve it?
Ian
Re: IMAP woes
26-03-2016 6:17 PM
Re: IMAP woes
26-03-2016 7:46 PM
In Thunderbird if you select the Inbox then menu item File and click on Subscribe a window should open displaying the (collapsed) Inbox. Expanding that should list all subfolders with ticked checkboxes on the right for those subscribed to.
If any are not subscribed to try doing so by ticking the boxes. Then click OK. Do they then show up in the account list?
Re: IMAP woes
26-03-2016 9:53 PM
Ian
Re: IMAP woes
27-03-2016 12:25 AM
Quote from: spraxyt In Thunderbird if you select the Inbox then menu item File and click on Subscribe a window should open displaying the (collapsed) Inbox. Expanding that should list all subfolders with ticked checkboxes on the right for those subscribed to.
Re: IMAP woes
27-03-2016 8:20 AM
Re: IMAP woes
27-03-2016 10:16 AM
Phil
Re: IMAP woes
27-03-2016 10:18 AM
Re: IMAP woes
27-03-2016 10:20 AM
I don't think it is a general problem with Plusnet but I do think there is something up with this mailbox. If not why would every email client behave incorrectly in exactly the same way?
Re: IMAP woes
27-03-2016 10:31 AM
Re: IMAP woes
27-03-2016 11:51 AM
Re: IMAP woes
27-03-2016 1:05 PM
Re: IMAP woes
27-03-2016 2:33 PM
The correct format is 'Inbox', which I was using. Out of interest I changed it to './Inbox' and all sub-folders disappeared, so I changed it back.
I have created a new PlusNet mailbox, created a number of sub-folders and set it up in Outlook. It works perfectly, sync'ing folders whether created in Webmail or Outlook. This seems to support my idea that the problem is a corruption in the PlusNet mailbox, but I have no idea what I can do about that so am waiting to see if PlusNet will now help.
If anybody knows how I can repair IMAP in a mailbox I'd love to know.
Ian
Re: IMAP woes
27-03-2016 2:47 PM
Re: IMAP woes
27-03-2016 4:43 PM
