I am having problems with Greenby
FIXED- Subscribe to RSS Feed
- Re: I am having problems with Greenby
- « Previous
- 1
- 2
- Next »
Friday
Hello @jab1
Judging by the facts that they got my email working, but haven't managed to get me able to log in to their website, I think they are a bit of a mix.
I will try them again on Monday - I doubt they work much on a Saturday. I have asked them if they could tell me just which email I need to log on, and I have given them a few examples of what it might be, they dont seem to be making much progress. I would have thought they would be able to search for which account uses one of my email addresses, or failing that give me a better idea of what my sign on email would be even if they just wrote "it woul;d like something like this" and replace my name from it with something that was a clue.
Anyway, thankyou for your help (and to the others that have joined in).
Saturday - last edited Saturday
The pdf you attached of your logon page I think shows you are trying to login to the Greenby internal support site - not the user portal!
Make sure you select the correct provider.
Sunday
Hello @mavison . I had tried that yesterday, and I tried various other things too but all failed. I'm wondering if all my failed attempts resulted in me being locked out of my Greenby account. I guess that lockout cleared over night because I tried your method (and others who suggested the same thing) just now and I got in. Hooray!!
My thanks to you and all the others who tried to help me. I'm really grateful
Sunday
Hello all,
To be fair (it wasn't his fault it wouldn't work for me), because jab1 was the first to suggest using "greenby.com", I have ticked the "This solved my problem" on his response.
Cheers
Sunday
"I've attached a pdf file of that part of the process of logging on to Greenby, but I haven't been able to open it to check that what I have put there is just the picture of that page."
That's weird. I have been using Greenby webmail since early this year, plus logging in to the Greenby account website and I have never seen a login page like that before now!
I note it says "Greenby" and "Support portal" - so not the usual Greenby account site? How is it related to these Greenby pages?
Sunday
Sunday - last edited Sunday
...That leads, as above, to: https://greenby.com/remote
Sunday
OK, @pvmb .As I said, I have never clicked it, so it was a guess, sorry.
Sunday
I found the support site by doing a google search for greenby then following links to greenby - login.
Just shows that using google can lead you astray!
- « Previous
- 1
- 2
- Next »
