How do I set up Thunderbird for Plusnet emails
chandu
High Guys,
I have downloaded the Mozilla Thunderbird ver: 9.3.1, but cannot set up.  Please I need step-by-step help to set it up as a  client.
Your help will be much appreciated.
Regards,
Chandu
5 REPLIES 5
C1Rider
Re: How do I set up Thunderbird for Plusnet emails
I'm in the process of setting up Thunderbird with Plusnet.
Will reply later if now-one else has..
Regards..
chandu
@C1Rider ,
Thank you very much for your response.  Please let me know how you get on setting up the Thunderbird for your Plus Net e-mail account and the step-by-step procedure will be very helpful.
Many thanks,
Chandu
chandu
Hi Guys,
It is NOT supposed to be PROBLEM FIXED, it show how often I use the community forum.
Please ignore the Problem fixed and please respond with your step-by-step procedure.
Thanks you.
Chandu.
C1Rider
In Thunderbird Account settings :-
Account Name  [email protected]
Your Name :  What you want others to see
Email Address : same as Account Name
Reply-to Address : nothing here
Organisation : nothing here
Outgoing Server (SMTP):
Same as Account Name and followed by - relay.plus.net(Default)
[ PRESS OK BUTTON ]
Server Settings
Server Name : imap.plus.net   Port: 993
User Name:  same as account name
Connection Security: SSL/TLS
Authentication method: Normal Password
[ PRESS OK BUTTON]
No more changes in that section, move to Outgoing Server (SMTP)
Box on left of [ ADD ] button should show
Account Name followed by - relay.plus.net(Default)
Details of selected server:  should show
Description: <not specified>
Server Name: relay.plus.net
Port: 587
User Name : same as Account name
Authentication method: Normal password
Connection Security: STARTTLS
Press the [ OK ] button
The above is showing in my Thunderbird and I can send to and receive from Plusnet.
Regards..
chandu
@C1Rider
Thank you for posting the Thunderbird set-up procedure for everyone to use.
My downloaded Thunderbird is version: 91.3.0 and hopefully it works.
Many regards,
Chandu.
